Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 07-14-2012, 12:52 PM   #1
youpers
Member#: 8988
2000 L GT
White & blue
Default Need help with cam sensors in STI swap
I swaped a 06 STI into my older LGT, which I use to have an older V7 STI installed in. The problem I am coming up against is that the cam sensors on the new heads have a three wire connection, whereas my harness has plugs for two wire cam sensors. The good news is that I have a Hydra ECU, so I could add new plugs in the harness for the new cam sensors.
Does anyone know if this is possible or how to wire it... Or if I should just get the Cosworth cam sensor brackets, and if so can I use the 06 STI cam gears? I would like to avoid spending $160 for brackets if I can.
PS: I already have the AVCS wired up and working just fine.
youpers is offline   Reply With Quote
Old 07-17-2012, 01:42 PM   #2
youpers
Member#: 8988
2000 L GT
White & blue
help...
Old 07-28-2012, 01:03 AM   #3
amroof
Member#: 211224
2005 Mystical
UniCorn FXTi
look up torque solutions cam bracket. and the sti avcs cam gear will and has the marks on the back of the gear for the pick up of the 3rd cam sensor on the drivers side front head.
let me know if you have any more questions
amroof is offline   Reply With Quote
Old 07-28-2012, 01:09 AM   #4
youpers
Member#: 8988
2000 L GT
White & blue
Thanks for the reply, I actually didnt need to add a bracket to run the old cam sensor. The mount was already there, it is what I am doing until I can figure out the pinout of the newer hall effect type cam sensors.
Old 08-01-2012, 10:39 PM   #5
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
If you have them wired up and working then why are you wanting to switch exactly?
Also, please post pics of your swapped legacy so we can be legacy swap friends.
Ben
