#51 |
Member#: 143149
Vehicle:2006 Evo IX RS used to be 07 wrx 6speed |
Yes, my current set up sucks and literally provides no flow to the manifold as evidenced by the extreme turbo surging that is quickly dying out. I need to bypass a lot more air to the exhaust manifold, and use less in the motor.
#52 |
Member#: 184747
Don't think anyone posted up the whole article from motoiq, just the teaser. http://www.motoiq.com/magazine_artic...preza-sti.aspx
In need of the "rocket"? http://www.subaruwrcspares.com/11.html Love this site!!! |
#53 |
Member#: 182415
Vehicle:1999 RS Aspen White |
Been reading up on the Evo SAS system, it seems very simple. Once the ECU see's its within the parameters to turn it on, it just retards the timing on throttle lift-off to get fuel into the exhaust, then opens the dump valve to let air into the manifold, creating combustion in the turbo. Did i get that right? What can we use in our ECUs that can run a solenoid to do that?
#54 |
Member#: 158767
that is the VERY basic idea of the system indeed
In order to make it function properly it does take a good amount more tuning than you might expect. If you wanted to correctly run this on stock subi ECU i'm sure it is possible but i wouldn't expect writing that patch would be an easy task not to mention when running a rally style ALS it is VERY important to have some fail safes so you don't melt and or over spin the turbo. Don't get me wrong, I would love to see the stock subi ecu controlling a secondary air injection set up ![]() |
#55 |
Member#: 158767
Thought i already shared this here but guess not. Set this up on a KA24-t running V1 AEM, I have a few video clips floating around as well i'll post up as soon as i can. (Should have been a lot of clips from the track but we were rained out!)
