Old 08-31-2002, 02:44 PM   #1
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
Default idea: turbo lag can be your friend
has anyone here thought of using a turbo big enough that it couldnt spool in 1st gear fully so that it would help prevent stripping 1st and 2nd gear
something equiv. to a full t4 or t6 sized compressor?
my idea is this...lag in 1st gear (we can sitll pull a good 1.8-1.7 60ft) and then be able to almost reach full boost in 2nd and finally full boost in 3rd.
this would give us better top end and most likely not stress the drivetrain as much
its always 1st and 2nd gear that break
why?
because those gears multiply the torque going to the ground.
they can make 400 hp look like 800 hp REAL quick....thus snapping **** all over the place
its really the torque that kills us also
any ways to get rid of torque and raise hp?
cams maybe?
OneArmedScissor is offline   Reply With Quote
Old 08-31-2002, 03:09 PM   #2
Ethon
Member#: 21907
hp is calculated from torque though.
Isnt it like hp=([tq*rpm]/5252) ?
Ethon is offline   Reply With Quote
Old 08-31-2002, 03:14 PM   #3
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
yes but cars like hondas and toyota celicas (with the 2zz engine)
use their RPM to create power
this can be done on a subaru as well
i was wondering if a lghtweight flywheel could help this
i had an 8lb one in the celi
and i could demolish LT1's and BPU boost raised GTi
Old 08-31-2002, 04:20 PM   #4
jmott
Member#: 6713
2007 Prius
brown
uh huh
demolish LT1s?
timeslips?
and if thats how you want to avoid tranny damage, fine.
but turbolag sucks ass (for me)
and yes, a lighter flywheel could help reduce the pounding put on 1st and 2nd gear when you shift/launch hard.
however, good luck getting a 1.8 60ft time witha lightweight flywheel. ESPECIALLY if you have a laggy turbo
jmott is offline   Reply With Quote
Old 08-31-2002, 10:01 PM   #5
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
the only way i demolished them was from a roll
keep in mind i had "full interior" (interior...whats that?)
i never EVER drove hard from 1-2 because of all the problems
one week i got overconfident
practiced driving, did some street racing
and the day before my track/dyno session
blew my transmission to all hell.
it took one week to blow the bastard to smithereens.
i did woop up on an m3 pretty hard...it was red.
Old 09-01-2002, 12:39 AM   #6
morphgabbin
Member#: 15466
2002 wrx
Originally posted by jmott
however, good luck getting a 1.8 60ft time with a lightweight flywheel. ESPECIALLY if you have a laggy turbo
Why would it be hard to get a 1.8 60ft with a lightweight flywheel? The only thing I can think of is that it wouldn't create enough load on the motor to build high boost, is this the reason?
morphgabbin is offline   Reply With Quote
Old 09-01-2002, 01:41 PM   #7
EJ2002
Member#: 23438
2002 WRX Sedan
Default what about?
milin-
i saw u run a black on black celica one time, and u had ur ass handed to you. was the black celica turbo? i thought i heard a BOV. either way LT1=owns u!!!
EJ2002 is offline   Reply With Quote
Old 09-02-2002, 12:16 AM   #8
impreza.J
Member#: 23852
2001 impreza rs
black
interesting proposal..need some time to think & research it.but really not sure. heres one though(if your looking for the best e.t's)..run a t66 and spray it. use a regulator that cuts the gas @7psi..no lag at all.
anyone else try this?
impreza.J is offline   Reply With Quote
Old 09-02-2002, 12:16 AM   #9
impreza.J
Member#: 23852
2001 impreza rs
black
Old 09-02-2002, 12:24 AM   #10
negativelift
Member#: 20783
energy storage, daniel-san.
negativelift is offline   Reply With Quote
Old 09-02-2002, 09:54 AM   #11
jmott
Member#: 6713
2007 Prius
brown
no.
mostly the reason is most of the energy used to initially launch your car is the kinetic energy stored in the flywheel spinning real fast.
our motors don't have enough power to launch the car hard without that.
also though, if youve figure out the trick that you can build a little bit of boost on launch by blipping the throttle just right, that trick would be less effective with a lightweight flywheel as well.
Old 09-03-2002, 12:50 AM   #12
OneArmedScissor
Member#: 18958
08 STi
Black as my heart
ive found that with my light flywheel on the old car
(8lbs)
you just had to slip the hell out of the clutch to get a good launch.
i HAD to launch much closer to 7k rpm...but NEVER dump it...just slip until it moved.
very tricky!
Old 09-03-2002, 07:28 AM   #13
VetteVert
Member#: 5961
2005 STi
CGM
Another point: A lot of the broken trannies are 3rd gear. There is less torque multiplication, but that is where the heavy load is. More than one 3rd gear drop from a roll-on, not shifting. See sponaugle's video for a graphic example.
VV
VetteVert is offline   Reply With Quote
Old 09-03-2002, 08:41 AM   #14
jlw
Member#: 12654
02 WRX Sdn, 2.5L
Element Tuning GT65r/hdrs
VV
What is a "roll-on"?
Where is the video?
jlw is offline   Reply With Quote
Old 09-03-2002, 09:10 AM   #15
VetteVert
Member#: 5961
2005 STi
CGM
roll-on meaning he wasn't drag racing, and power-shifting into 3rd. He was already in gear, and the torque load blew 3rd gear.
Where is the video?
Here is the video.
VV
Old 09-03-2002, 11:52 AM   #16
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
I do that 3rd gear stuff all the time.
No more though after hearing this
MAD REX is offline   Reply With Quote
Old 09-03-2002, 12:45 PM   #17
GRoceryTurbo
Member#: 9407
02 WRX
platinum silver
VV
is this a common problem with transmissions, I thought everyone was tearing the teeth off the main shaft. how much power was this guy making and what kind of mods did he have?
~John-who is now scared of a turbo up-grade.
GRoceryTurbo is offline   Reply With Quote
Old 09-03-2002, 12:53 PM   #18
VetteVert
Member#: 5961
2005 STi
CGM
More common among those with more power. sponaugle runs a VF22 + FMIC + associated goodies last I knew. I think he was running 22psi when 3rd gave way. He did it twice (maybe more) and now has a stiRA powertrain.
VV
Search for sponaugle and read his stuff in the tranny forum. I am paraphrasing (from memory ) his mods/problems.
Old 09-04-2002, 12:48 AM   #19
Chris-BoT
Member#: 11829
2002 WRX Wagon
Wink
Here was Jeff Sponaugle's website. He's got some nice pics of his now defunct tranny.....
http://wrxworld.com/
Chris-BoT is offline   Reply With Quote
We can dance if we want to, we can leave your friends behind UberWilhelm Off-Topic 20 10-09-2009 02:30 PM
Worst thing friend can do and still be your friend? ulagic Off-Topic 8 07-10-2006 01:30 PM
crushes that happen to be your friend onesillyracer2k2 Off-Topic 67 06-21-2006 02:00 AM
You can choose your friends, but you're stuck with family Turboman93 Texas Impreza Club Forum -- TXIC 18 01-16-2004 11:38 AM
Linux CAN be user friendly chkltcow Off-Topic 8 12-02-2003 12:43 PM
