Old 07-17-2012, 09:04 AM   #1
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Default Late EJ20G in 99RS, boost solenoid or MBC?
I would like to have a legit boost solenoid I could plug in and not have a CEL, but I realize how simple an MBC would be to use.
Do you guys have good experience with a particular brand of either boost solenoid or MBC? I've seen the Perrin MBC, and they can usually be trusted.
Any input helps! Thanks
GGSimpreza is offline   Reply With Quote
Old 07-17-2012, 09:26 AM   #2
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
I am currently using a perrin mbc and it seems to get the job done well, if I was to change it out I would probably go with one from grimmspeed or possibly a hallman pro.
spackyscooby is offline   Reply With Quote
Old 07-17-2012, 11:47 AM   #3
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Yeah I've got a lot of Mitsubishi friends who love the Hallman, and it's close to the same price of the Perrin, so I have been leaning that way. Thanks
Old 07-18-2012, 04:26 AM   #4
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
I'm using the Hallman right now.
Smoke is offline   Reply With Quote
Old 07-18-2012, 12:31 PM   #5
turboaddiction
Member#: 257266
ive had the plain turbo xs one and currently use a turbo xs high performance both are great
turboaddiction is offline   Reply With Quote
Old 07-22-2012, 07:19 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
I have a hallman and the factory bcs is still plugged in with no hoses going to it, no cel.
Old 07-23-2012, 09:34 AM   #7
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I'm gonna have CEL due to my exhaust, but I'm gonna try and take them down 1 by 1. Anybody know how to get around the CEL with no BCS? Or where I can get one that will work.
Old 07-23-2012, 09:39 AM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
Why would the exhaust give you a cel? The EJ20G isn't obd2, no 2nd O2 sensor.
You could try a resistor in place of the bcs, it should work.
Old 07-23-2012, 10:34 PM   #9
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I figured. What size resistor?
Old 07-24-2012, 11:08 AM   #10
69subaru360
Member#: 159682
1995 WRX
2015 F150
You'd have to measure a bcs with a mulitimeter and get one. I'd do it for you but my meter is acting funky lately. Maybe somebody else can?
Old 07-25-2012, 07:23 PM   #11
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
I'm currently running a grimspeed MBC on my 20g and so far i have no CEL. granted the cars only run for about 5 minutes with it on, but the how to that I read said that as long as you leave the stock solenoid plugged in, weather or not boost lines are running to it, it wont throw a code.
Edit: as you can see, i simply took out the in and out lines for the solenoid and plugged them into my mbc.
Millhouse_5 is offline   Reply With Quote
Old 07-26-2012, 03:09 PM   #12
Jarrod164
Member#: 253937
1995 WRX
Hate to burst your bubble or perhaps I'm reviving your car and you're going to love me but it looks like you have your MBC hooked up incorrectly! The two horizontal lines are the ones to hook up not the bottom line. The bottom line goes to your resonator box and should be plugged off.
http://forums.jdmvip.com/How_to_Inst...Impreza-3202-t
Jarrod164 is offline   Reply With Quote
Old 07-26-2012, 07:49 PM   #13
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I would love if someone could do this.
I don't have the stock one, since I didn't by a JDM front clip. If I did, this thread would not exist. Trying to find a solution for CEL since I don't have it.
Old 07-27-2012, 06:02 AM   #14
Flavah
Member#: 220801
1994 WRX RA
I can look and see if I have a boost solenoid laying around. IIRC, I have a 2 port and a 3 port but I need to look since I just got back to Japan from the states. PM me if interested and we can chat.
Flavah is offline   Reply With Quote
Old 07-27-2012, 11:38 AM   #15
Jarrod164
Member#: 253937
1995 WRX
If I remember over the weekend... or maybe someone else can check this but we could take the plug off of our boost solenoids and take a multimeter and measure the resistance. That'll tell you what size resistor to use
Old 07-31-2012, 08:52 AM   #16
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Can someone do this? Haha it would help out tremendously!
Old 07-31-2012, 11:03 AM   #17
Jarrod164
Member#: 253937
1995 WRX
I was gonna do it last night but ended up not haha. I will be under my hood tonight so I'll let you know.
Old 08-01-2012, 09:59 AM   #18
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
Cool, thanks dude!
Old 08-01-2012, 10:12 AM   #19
Jarrod164
Member#: 253937
1995 WRX
21.5 ohms!
Seems like a really low number. If you look at the picture above, you can see the red and black wire sticking out of the left of the solenoid. That runs to a little black plug under that guys MBC. That's where I measured and I assume that's the plug you have just dangling there.
Good luck and let us know if that gets rid of the CEL!
I guess it should work out as the rest of us just have that hooked up. I was wondering if a different resistor size would affect the ECU. Does the ECU pick up signals from the unit or does it send signals (or both)? Just thinking about if the ECU sees boost from that solenoid but that wouldn't make sense with an MBC in the picture heh.
Old 11-02-2012, 08:59 PM   #20
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I'm gonna do that when I get back from FL. I wonder if it has to be exactly 21.5 ohms...
Old 11-13-2012, 11:15 PM   #21
GGSimpreza
Member#: 291739
99 Impreza RS
Silver Milage
I put a 22 ohm resistor in, got rid of my 4500 rpm fuel cut. However, has a stutter at wide open throttle in 3rd and 4th sometimes. I'm probably maxing out my MAF right? That's what it feels like.
