Old 07-17-2012, 11:58 PM   #1
Dr Oppopuss
Member#: 312599
2011 WRX Limited
World Rally Blue
Default Ordered Cobb AP Stg.1, couple questions...
Car: 2011 WRX Sedan
Mods: Namless Muffler delete axle back
Just ordered my AP. I'm going to be running the OTS Stage 1 map.
My questions are as follows:
I'm at about 6k miles, and don't plan on doing any other power mods until my warranty is up. Would a Protune be worth it? After doing research the only consistent answer I could find was "No because you're gonna go stage 2 so soon anyways, etc" but personally, I'm not.
Second: Will the OTS map be ok in Michigan winters? I guess if not I should just get a protune in the winter time.
Thanks for the help, and I did a lot of searching first.
Dr Oppopuss is offline   Reply With Quote
Old 07-18-2012, 12:01 AM   #2
savvy
Member#: 127208
2011 STI
You can consider your warranty void as soon as you flash stage 1. Dealerships can tell if the ecu has been flashed and can deny warranty coverage because of it.
savvy is offline   Reply With Quote
Old 07-18-2012, 12:18 AM   #3
Dr Oppopuss
Member#: 312599
2011 WRX Limited
World Rally Blue
Thanks for the information. I've read way too many threads and posts on this subject and will take my risks with just an ecu flash. I don't want this to turn into another "Void vs denied" warranty thread.
Old 07-18-2012, 10:56 AM   #4
Cobb Tuning
Member#: 4803
Originally Posted by Dr Oppopuss View Post
Car: 2011 WRX Sedan
Hi there. You can certainly find gains with a stage 1 protune - really just depends on your goals and how your car responds. However, if you get a stage 1 protune and then go stage 2, you will still have to get a re-tune if you also want a protune on stage 2.
Bill
Old 07-20-2012, 05:45 PM   #5
Dr Oppopuss
Member#: 312599
2011 WRX Limited
World Rally Blue
Thanks for the information Bill.
Can you, or anyone in a cold climate speak to how the Cobb OTS map does in winter time?
Old 07-20-2012, 05:58 PM   #6
Cobb Tuning
Member#: 4803
Sorry - I missed that in your original post. The OTS maps will not generally have any problems with cold vs. hot weather. Occasionally, some cars will see more boost (or overboost) during cold weather, but this is usually those who are running a catless exhaust. You can certainly get a data log now and when the temps drop to check your boost levels (check out our data logging video below). We do have low wastegate maps you can use if you find that your particular car is overboosting.
Bill
Old 07-20-2012, 06:01 PM   #7
Dr Oppopuss
Member#: 312599
2011 WRX Limited
World Rally Blue
AskCOBB - Subaru Data Logging - YouTube
Bill
Awesome, thanks for the quick responses. It's nice to buy a product and recieve customer support for a change! I see why Cobb gets so much repeat business now.
Old 07-20-2012, 06:03 PM   #8
Cobb Tuning
Member#: 4803
No problem - glad to help!
Bill
