Old 07-18-2012, 02:51 PM   #1
rdecker20
Member#: 309444
2005 sti
Default Quick question
I need to tap into a wire that is only on while cranking preferably under the dash somewhere. Also in an 05 sti. If anyone could help me quick I'd appreciate it. Thanks
rdecker20 is offline   Reply With Quote
Old 07-18-2012, 08:07 PM   #2
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
A wire that has power only when cranking? I think the only wire that fits the description would be the one that carries the signal from the ignition to starter solenoid (or wherever it goes in between)
what is it for?
aerosaaber is offline   Reply With Quote
Old 07-18-2012, 09:46 PM   #3
rdecker20
Member#: 309444
2005 sti
I may have not been specific enough. I need 12v to power a relay only while the car is running so the relay is not energized while the car is off.
Old 07-18-2012, 10:52 PM   #4
El-ZackO
Member#: 271260
99 OBS
Green/Grey
Stereo power line? Or possibly amp power line (if amp/sub installed)
El-ZackO is offline   Reply With Quote
Old 07-19-2012, 09:05 AM   #5
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
You need a switched power source. Radio or cig lighter power wires will work fine. Just test whatever wire you use with a test light and make sure it shuts off when the ignition is turned off
J.Gibbs is offline   Reply With Quote
Old 07-19-2012, 08:21 PM   #6
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
OK, that makes a lot more sense.
TONS of options for that, I usually use an "add-a-circuit" that plugs into a fuse location and give me a wire w/ it's own fuse. I can't remember which fuse I normally use.
Old 07-19-2012, 10:10 PM   #7
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
I always use inline fuses with any new power wire that I add which isn't wired into a fuse block. Better safe than sorry
Old 07-20-2012, 07:55 PM   #8
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
fuses are great, until they start acting all "hey I look ok, but really I've failed, but I look ok so go search for a problem for 3 hours before just swapping me with a good fuse and solve the problem" lol rage.
Old 07-20-2012, 07:56 PM   #9
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
(I always run fuses on stuff, I don't want to burn my car down)
Message Board Statistics All times are GMT -4. The time now is 07:12 AM.
