Old 07-18-2012, 06:38 PM   #1
jdmwrx94
Member#: 211619
94 jdm wrx
red
Default getting 550 rdy
Hey,
Ordered my 550 eprom (upgrading from 440), carl davey adaptors ordered, found some yellow sti for cheap, new injectors o-rings ordered, and the cx-racing fmic en route, can't wait to install everything and have it running!
questions to those who installed the cx-racing fmic, is there a bov flange somewere or i need to customfit one? and you guys ran into problems of any kind?, (herd about leaking couplings) anything else?
jdmwrx94 is offline   Reply With Quote
Old 07-19-2012, 01:42 PM   #2
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Nice, I've been wondering weather or not to go 440 or 550 with my sti. I'd love to hear your impressions on the comparison when you get this all done.
I dont suppose you've dyno'd this setup have you. seeing some numbers would be great
Millhouse_5 is offline   Reply With Quote
Old 07-19-2012, 07:58 PM   #3
jdmwrx94
Member#: 211619
94 jdm wrx
red
I havent dynoed the 440, it ran 13.5 @ 101mph
Old 07-20-2012, 01:13 AM   #4
seangfy
Member#: 242150
1993 impreza L ej20g
aquafrost blue
What mods do you have? I have a 440 and haven't had a chance to run it yet
seangfy is offline   Reply With Quote
Old 07-20-2012, 03:30 AM   #5
jdmwrx94
Member#: 211619
94 jdm wrx
red
nothing unusual, 3in decated tbe with 2.5in axleback, went back to stock airbox, was pumping too much heat waiting in line for the dragracing. that's prettin much it
Old 07-20-2012, 11:14 AM   #6
seangfy
Member#: 242150
aquafrost blue
Thanks I'm running completely stock on mine at the moment.
Old 07-23-2012, 07:07 PM   #7
69subaru360
Member#: 159682
1995 WRX
2015 F150
Originally Posted by jdmwrx94 View Post
Hey,
There is a flange but it's in an odd location and points right at the starter. It work if you use a 90 degree fitting.
The clamps it comes with aren't great. Some of mine leaked and I just used regular hose clamps.
If fits better if you cut the pipe in the area behind oil cap and add another coupler.
Old 07-26-2012, 09:09 PM   #8
jdmwrx94
Member#: 211619
94 jdm wrx
red
thx for the feedback!
i removed old timing belt, it was due, but I have a problem with my crank pulley, hope I can repair this without replacing the crank shaft... maybe a new key and pulley will suffice...
http://youtu.be/r-0AczN4b38
Old 07-30-2012, 07:30 PM   #9
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Owch! 99 Forester (EJ253) has same crank sprocket as EJ20G fyi. I don't know how hard it is getting EJ20G parts in Canada
tenchu is offline   Reply With Quote
Old 07-31-2012, 03:16 AM   #10
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
If the slot in the crankshaft is worn there's no long term repair unfortunately. Crank needs te be replaced.
Marnix is offline   Reply With Quote
Old 07-31-2012, 10:10 AM   #11
69subaru360
Member#: 159682
1995 WRX
2015 F150
JB weld actually holds up really well for this. Set the new key in place. Spread the JB around in the worn out slot in the crank and put a new crank gear on and tighten the bolt before it dries.
I've also tack welded the key in then filed the welds down to get the gear over.
Really the key just aligns it. The 100 ft lbs you torque it too holds it in place.
Ones I've fixed for people years ago are still running.
Old 07-31-2012, 01:26 PM   #12
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
I think the key does more than just align. I believe it also keeps the pulley from drifting out of alignment over time. It would be a fun experiment to line it up without the key and check in a few thousand miles if the pulley moves out of place
It is also possible to cut a new channel exactly 180deg from the damage section of the crank. Although, the crank has to be out to do this anyway, so might as well replace the crank.
-Rob
rob is offline   Reply With Quote
Old 07-31-2012, 07:52 PM   #13
jdmwrx94
Member#: 211619
94 jdm wrx
red
The key was broken as the edge of the keyway, I will repair it with a new key, and liquid steel, the pulley bore is good 24mm and key way too... unexpected... I will not open the block, I had oil leaks one behind and one in front. so I took some parts off to find out the hoses under the throttle body were bad and I will replace every rubber hoses in front and reseal the oil pump.
can that hose drops oil here and there over time and buildup a mix of oil and sand and dust over time, the block is so dirty it's unbeleavable! (I did clean the front part a lot)
I recieved the cx-racing intercooler, but it seems I will have more than a blast trying to install this... It's HUGE, I doubt it fits under the bumper...
Old 07-31-2012, 11:03 PM   #14
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Man that thing is shiny, hahaha. Let us know how the install goes! I was planning on picking up a CX Racing kit for my EJ20G GC as well..
