Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 08-07-2012, 11:45 AM   #151
Squidz
Member#: 142608
2003 Sonic Yellow
Marginally well behaved.
Awesome. That extra 100 WHP has to completely transform this car into what it really should be. The TQ curve is amazingly flat...nice job guys.
I also drove the BRZ and felt that it did not live up to the hype. Slower than a miata and handled about the same for a stock car. Really needed more engine to make it as good as they said it is...IMHO.
Squidz is offline   Reply With Quote
Old 08-08-2012, 01:52 PM   #152
TuningIsLife
Member#: 191380
2014 Jeep Wrangler
Hydro Blue
From a guy that used a prototype kit to turbocharge an xB. This is badass and I look forward to seeing where this goes.
TuningIsLife is offline   Reply With Quote
Old 08-08-2012, 02:50 PM   #153
REX8
Member#: 24038
Originally Posted by Squidz View Post
Slower than a miata
No, it's not. It's as fast as your WRX is (stock to stock).
Old 08-08-2012, 07:58 PM   #154
eekay
Member#: 205501
1999 Legacy GT 2.5L
Erm? How do you figure? Power-to-weight, the WRX has more. BRZ's 0-60 is 6.4 seconds while the '03 WRX is 5.6 (nearly a second faster) and the WRX's turbo will only make the distance between the two cars even greater as the run gets longer... I'm stumped.
eekay is offline   Reply With Quote
Old 08-08-2012, 10:27 PM   #155
DONx3
Member#: 214050
2007 WRX
World Rally Blue
Wow Toledo getting recognized for something? I can officially be proud of being an alumni from that city!
DONx3 is offline   Reply With Quote
Old 08-08-2012, 11:30 PM   #156
StackSmasher
Member#: 316928
2012 STI limited
Did you miss the dyno graph where this thing is making 272 whp?
StackSmasher is offline   Reply With Quote
Old 08-08-2012, 11:33 PM   #157
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
Pretty sure he was comparing stock to stock. Not really fair to compare a modded brz to a stock Wrx. If ur gonna do that I'd at least use a modern wrx and not the 7-10 year old ones
Phatron is online now   Reply With Quote
Old 08-08-2012, 11:38 PM   #158
eekay
Member#: 205501
1999 Legacy GT 2.5L
Did you miss where the replied to wrote "(stock to stock)"?
Old 08-09-2012, 12:12 AM   #159
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
You do realize that you have to consider power at the wheels and not power at the crank when comparing power-to-weight ratios? You do know about drivetrain losses? Right?
2003 WRX --> 180whp and 3100 lbs --> 17.2 lbs/hp
2013 BRZ --> 160whp and 2800 lbs --> 17.5 lbs/hp
It's awfully close. On a proper road course, after a couple of corners, the WRX would loose whatever lead it managed to build up.
neg_matnik is offline   Reply With Quote
Old 08-09-2012, 12:27 AM   #160
Phatron
Member#: 36033
CEO PhatBottiTuning
^ how did u account for awd v rwd on the track?
Comparing cars like that is pointless. Anything that close is gonna be all driver. Even cars 150hp+ apart can be decided by driver.
Old 08-09-2012, 01:34 AM   #161
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Why cant you compare the two. Same driver for each car battling for the fastest track time sounds like a fair comparison to me. Awd, fwd, rwd, 4wd, whatever. Two cars enter, one car leaves.
Old 08-09-2012, 01:40 AM   #162
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Thats if you get a 160whp hp car.. I have seen two dynoed an FRS auto and a BRZ stick the brz dynoed 154-156 and it fell each successive run.. The Auto FRS dynoed like 150 and the second run it dynoed 134.
I dont think you can compare the two they are not similar platforms. Driver matters more.
That turbo kit sure does help the car though.. Thats how it should of came stock. Then Again I dont think they are aiming for it to compete against the wrx/sti and others
Dat8687 is offline   Reply With Quote
Old 08-09-2012, 01:49 AM   #163
Phatron
Member#: 36033
CEO PhatBottiTuning
in an actual race, yes.
but simply saying x car has lb/hp vs y car with lb/hp....
just saying trying to pick a winner on paper is pointless.
and i really dont know why we're comparing 2013 cars to 2003 cars....
Old 08-09-2012, 02:00 AM   #164
eekay
Member#: 205501
1999 Legacy GT 2.5L
The debate started due to the mention of the BRZ being slower than a Miata with a reply of "Faster than your WRX stock vs stock". In all honesty, I don't care how this car compares to an STi or anything else Subaru makes. I want to see how it compares to other cars in it's class. Especially after this turbo job...
Old 08-09-2012, 03:04 AM   #165
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
And I agree. I was just reacting to eekay saying that the 03 WRX had an advantage in power-to-weight ratio. I was just showing that the numbers are actually very close.
But, the BRZ is 300 lbs lighter than the 03 WRX and that's going to matter around corners.
Old 08-09-2012, 04:41 AM   #166
eekay
Member#: 205501
1999 Legacy GT 2.5L
It will matter around corners. But, so will the turbo boost out of a corner (if the corner is driven correctly). Regardless, I really just want to see what becomes of this BRZ. I'd love to see it be absolutely great.
Old 08-09-2012, 07:37 AM   #167
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Nice car but as stated its legacy lays with the ae86.. Not a fast car by any means.. But lightweight and a good competer for its class.. Its powerband is the typical NA with a Bad Vtec design and its not Dynoing what it should stock.
A 200hp car dynoing 150-160 wheel is what a 25-20 percent loss in power..
However This FRS dynoed 173 STOCK..
A 2011 SI dynoed 192hp Stock
A 2012 SI dynoed 175 hp stock
Same dyno
http://www.8thcivic.com/forums/garag...rs-dynoed.html
Old 08-09-2012, 08:18 AM   #168
Boxer112
Member#: 78751
2015 WRX STi
Crystal White Pearl
My question is when is the restrictive stock exhaust going to be removed for a turboback and have that bad boy over 300whp?
Boxer112 is offline   Reply With Quote
Old 08-09-2012, 09:12 AM   #169
REX8
Member#: 24038
I said it's "as" fast as a stock 2.0l WRX.
Discounting the WRX's AWD launch (and thus faster 0-X times), their acceleration is dead on one another. Look at their near identical 1/4 mile trap speeds (the best indicator of power/weight and average acceleration). It's a dead heat.
As it's been said, countless times, for over a decade now: Excluding the AWD launch, a stock EJ20 WRX would run a low 6 second 0-60, and a 15 second 1/4 mile at about 95 MPH. Sounds like a BRZ doesn't it?
Old 08-09-2012, 09:17 AM   #170
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Discounting the WRX's AWD launch (and thus faster 0-X times), their acceleration is dead on one another. Look at their near identical 1/4 mile trap speeds (the best indicator of power/weight and overall average acceleration). It's a near dead heat once they're moving.
As it's been said, countless times, for over a decade now. Without the AWD launch, a stock EJ20 WRX runs a low 6 second 0-60, and a 15 second 1/4 mile at about 95 MPH. Sounds like a BRZ doesn't it?
The worst times i have seen out of a stock first gen wrx is mid high 14s. Again though drivers can make a 14 second car run 16s-17s
Old 08-09-2012, 09:19 AM   #171
REX8
Member#: 24038
Miss the part where I said "without the AWD launch"? Look at the trap speed...aka mid 90s. Once off the line, it accelerates as hard as a low 15 second 2WD car (like an RSX-S, etc.).
Again, you can't compare 0-X times AWD vs. 2WD. That's how idiots think, for example, their WRX/STI, which traps 103 in the 1/4, is as fast as a vette or a 911, which might run a similar 0-60 time, but traps 5-10 mph more
The same ridiculous rationale that got early WRX owners calling their cars almost equivalent in speed to LS1 Camaros and 911s, both running about 5.0 seconds to 60 at the time. Completely ignoring that once moving, those cars are vanishing out their windshield at an alarming rate.
Trap speed is a MUCH more accurate indicator of overall acceleration (and power/weight). Put the BRZ and the WRX exiting a corner together onto a straightway, and they're staying right on one another's doors.
C/N: If you think a BRZ is too slow to own, you must also think a 2.0l WRX is too slow to own.
Old 08-09-2012, 09:24 AM   #172
wrxlaunch
Member#: 181298
99 SF
http://www.zeroto60times.com/Subaru-0-60-mph-Times.html
I personally ran a 13.9 with bone stock 02 wrx and I'm 100% sure someone has gone faster...
wrxlaunch is offline   Reply With Quote
Old 08-09-2012, 09:48 AM   #173
REX8
Member#: 24038
Are you guys even reading the thread, or just posting whatever pops into your head?
Old 08-09-2012, 10:40 AM   #174
Squidz
Member#: 142608
2003 Sonic Yellow
No, it's not.
Yes, it actually is:
Brz:
0-60 - 6.4
1/4 - 14.9 @ 95.5
Skidpad - .92g
60-0 - 108 ft.
Miata:
0-60 - 6.3
1/4 - 14.8 @ 92.4
skidpad - .92g
60-0 - 120 ft.
With the BRZ having 33CHP more than the miata, these numbers are dissapointing. They handle about the same, and the BRZ (STOCK) is in fact slower.
I obviously havn't driven the turbo car, and it's amazing i have no doubt...but you can turbocharge miatas as well. Not taking anything away from what the guys are doing with this turbo kit...completely different car. But the fact of the matter is...the stock BRZ is in fact, slower than a miata...and handles about the same...for more money.
03 wrx: 0-60 - 5.7sec ... 1/4 - 14.2 @ 95.7
13 BRZ: 0-60 - 6.4sec ... 1/4 - 14.9 @ 95.5
I don't know where you learned to do math...but that's not quite the same...or even relaitively close.
Old 08-09-2012, 10:57 AM   #175
REX8
Member#: 24038
Brz:
0-60 - 6.4
1/4 - 14.9 @ 95.5
Skidpad - .92g
60-0 - 108 ft.
Miata:
0-60 - 6.3
1/4 - 14.8 @ 92.4
skidpad - .92g
60-0 - 120 ft.
YOU! Outta the pool!!!!!
Third guy in a row to not read before posting. Congrats! Thanks a lot of posting standing start acceleration numbers THAT NO ONE IS DISPUTING.
See the identical trap speeds of the WRX and the BRZ? It means that they have just about identical acceleration once moving.
The difference in the 0-60 and 1/4 mile times is down to the AWD traction off the line of the WRX, and not any added power/weight.
Jesus.
Do you post before you read? You only furthered the point being made.
The BRZ traps 3 mph faster than the Miata. So, on a road course, heading down the straight, guess which car is pulling away? Oh, that's right, the BRZ. Why, because, overall, it's a faster car.
Oh, I forgot, this is proven power bragging, where launching matters more than power/weight/acceleration.
When someone says one car is faster than another, what I assume you mean, is that, in gear, mashing the gas, which car will pull away. In that regard, the BRZ and the WRX are a DEAD HEAT with one another.
Apparently, your definition of "faster" means, which one can cut the faster 60' time.
Question:
Which one of these cars do you consider generally the faster accelerating car:
Car 1 (AWD): 14.1 @ 95
Car 2 (2WD): 14.5 @ 100
If you picked car 1, you're completely lost. Car 2 accelerates significantly harder than car 1...and only at a drag strip, with a hard standing start launch, would car 1 finish ahead of car 2.
I suppose my stage II WRX, which does 4.7 to 60, and traps 100 in the 1/4 is as fast as my M3, which does 4.7 to 60, and traps 104? The BMW WALKS away from the Suby once moving, it's not close. Only a true fanboy would attempt to argue that the WRX is as fast.
