#176 |
Member#: 116355
TXIC
Vehicle:2004 Impreza STI bassboat JBP |
I find it amusing the AP BRZ-300 vs the White FR-S w/ exhaust runs through a school zone
#177 |
Member#: 142608
TXIC
Vehicle:2003 Sonic Yellow Marginally well behaved. |
The comparison between the BRZ and the Miata has nothing to do with 60ft times...they are both RWD cars, with a six speed...similarly geared.
Yes, the WRX has an advantage out of the hole, but it would have the same acceleration and traction advantage coming off of an apex as it does out of the hole at the dragstrip. Drive either the wrx or the miata on a racetrack (back to back if you can) and you will see exactly what i am talking about. I completely understand how trap speed tells you about power to weight and acceleration...i have been competitively drag racing for almost 2 decades. I'm talking about putting power to the ground. With the double wishbone, torque-arm suspension in the rear, the miata puts the power to the ground better than the BRZ and therefore is ultimately a faster car in stock form. This is shown by the 1/4 mile times as the miata can get out of the hole and initially put more power through the drivetrain. The WRX obviously has this in spades over both of the other cars due to AWD. You are correct on your trap speed comparison...but you can't ignore what the other data from a quarter mile race tells us just to try to make your point. Last edited by Squidz; 08-09-2012 at 11:09 AM. |
#178 |
Member#: 177891
Vehicle:06 wrx wagon child seat/tow hitch cgm |
aero changes trap speed too...
#179 |
Member#: 142608
TXIC
^^ True, the BRZ is much more aerodynamic. It's a beautiful car.
#180 | |
Member#: 24038
South East
The 3 mph the BRZ has on the Miata is the only thing about those numbers that is really telling. And it's telling us that the BRZ accelerates harder than the Miata. A car that traps 100 will be at least noticeably slower than a car that traps 103. Certainly moreso than comparing a 5.1 to a 5.2 standing start time. And to the point, I'm not "ignoring" the other aspects of the data to prove my point. Only one bit of data gives an indication of acceleration without other factors significantly contributing to it (lauch, etc.). That bit of data is trap speed. |
#181 |
Member#: 142608
TXIC
But the trap speed can be affected by just as many 'outside factors' as anythig else can. How hard you launch the car can also drastically affect your trap speed, just as it can your times. You are also assuming that there were driver errors...they didn't just do one run and call it a day. They did several..and then averaged them together..i doubt they made the exact same mistakes each time.
The numbers aren't perfect on either side...so you have to take them as they are. 0-60 and 1/4 times the miata is quicker...is that .1 second going to be even noticeable at any point ever? No, it's not. The BRZ has a better power to weight ratio, is that going to make that big of a difference? It really should, but in reality it doesn't because the BRZ can't get that extra power to the ground in the right places. Mostly because of the torque curve...which is why it has to chase down a car with 30 less horsepower at the dragstrip. Combine all of this with the fact that it's more expensive... The BRZ is a really good car, but it's not excellent...The BRZ chassis is almost too good for 200 CHP. It really needs the kind of horsepower that these guys are making with this turbo kit to make it an excellent car. The miata started with 115 HP...and the same things were said about it in 1990. In all fairness they have been improving it for 23 years...and turned it into one of the best budget sports cars on the planet. So i can't wait to see where the BRZ is 20 years from now. |
#182 | |
Member#: 249068
South East
Vehicle:2010 WRX DGM Phatbotti Tuned |
#183 | |
Member#: 24038
South East
![]() I thought you said you drag raced? Trap speed is MUCH MUCH less affected by how good of a launch you have compared to ET. By the same token, driver error more greatly affects ET, compared to trap speeds. That's automobile performance 101. It's the reason trap speed is WIDELY regarded as the best indicator of power to weight, while ET isn't (as it is MUCH more driver dependent). Surely can't be arguing that. As to everything else your talking about, I don't disagree. The point was, is the BRZ faster than a Miata? I would say, in an overall acceleration sense, yes, the BRZ is the faster car. Not hugely so, but faster none the less. In fact, most of the Miata tests have it at like 15 flat at 90 mph. 3 mph on the trap is actually like an average EJ20 wrx compared to an EJ25 WRX. There's a good bit of difference in WHP/weight between those two cars, and it shows up in the trap speed. Last edited by REX8; 08-09-2012 at 01:41 PM. |
#184 | |
Member#: 24038
South East
From Motortrend's BRZ Review:
Look at that 5 mph difference in trap speed. The BRZ is seriously pulling on the Miata. No way if you had these two cars out on a road course, or the highway, would you say the Miata is the faster car. It simply is not. It's walking the Miata faster than an SRT-4 walks a WRX. ![]() |
#185 | ||
Member#: 142608
TXIC
How you drive the car, and launch the car can change trap speeds by 2-3 mph easily. Shift 100 rpm too soon or too late, loose a little traction going into second or third...it's all relative. Quote:
I know the BRZ has a better power to weight ratio...it should, it makes 33 more HP...but the plain fact that the numbers are so close with the BRZ having a 33 HP advantage tells you just how quick the miata really is...just how well the miata uses the power available to it. This translates into a much more driveable and ultimately faster car on the racetrack. |
#186 | |
Member#: 142608
TXIC
5mph difference in speed at 90 MPH...neither of these cars in stock trim are going to come aywhere near 90 MPH out of a corner. The BRZ will pull on it at the top of the straights...but it doesn't really translate to corner exiting as you stated before. I have had both of these cars out on the road...and on an autocross course and have driven many miatas on the road course (have not had a chance to steal a BRZ at the track yet ). I still say the miata, in stock form, would set faster lap times. These cars should not be this close with the BRZ having a huge power and weight advantage...that tells me that there is something about the BRZ that doesn't work yet. |
#187 | |
Member#: 302438
SWIC
Vehicle:10 WRX SS DMrally tuned! |
I 2nd this. I don't think Mr. nick knows WHY a high compression direct injected motor has to start with low boost. This is definitely a step in the right direction for this car!!! Well done guys! |
#188 |
Member#: 108051
Vehicle:2005 TickingTimeBomb Jr tuned TT Sleeved |
IDC if the Miata is fast IMO it's a girls car. It's tiny plain and boring unless it has an LS motor LOL. The BRZ/FRS is a good looking slow sports car. For now anyways. Someone need's to LS swap a BRZ.
#189 | |
Member#: 147678
E. Canada
Vehicle:07 wrx obsidien black |
#190 | |
Member#: 156247
Vehicle:05 STI-10.6 @ 134 GTR - 9.31 @ 151.78 |
#191 | |
Member#: 155696
Vehicle:2007 BLK STI Dom3XTR 415/405 Precision Tuning |
#192 |
Member#: 329151
Joined NASIOC just to see where this goes. Rode in a BRZ today and it was eye opening to say the least. For the price point you cant bet a better looking or feeling car. Depending on how this thread turns out I can see myself buying one.
Visconti, how much further do you think you can push the stock fuel setup? Any Idea what the stock fuel pressure is at? I'm interested to see how much the stock setup can be pushed. |
#193 |
Member#: 72042
South East
Vehicle:2002 WRX impreza WRB "Blue Mammoth" |
Nice job, the pull against the FRS was tremendous.
Kind of sad to see these cars done up for straight line racing. Would like to see them in time attack. |
#194 |
Member#: 329488
great job!
#195 | |
Member#: 156247
With the turbo car making 280whp I had pushed the fuel system as far as I wanted to. Next week I will be testing several sets of injectors and one or two fuel pumps. Shooting for At least 300 on pumpgas and even more on e85. John |
#196 | |
Member#: 260054
RMIC
Vehicle:2004 WRX Wagon Aspen White |
#197 |
Member#: 292357
Vehicle:2004 WRX WAGON WRB |
Great work accelerated and visconti, this car should be pretty rad within the next couple months!
#198 |
Member#: 160782
NESIC
Vehicle:2004 Impreza WRX STi Java Black Pearl |
#199 |
Member#: 205501
Vehicle:1999 Legacy GT 2.5L Silver |
Saw the 11.3 @ 127! Bang up job, Visconti!
#200 |
Member#: 156247
Thanks everyone
One side of me says " don't touch it" the other side says "500whp or bust" |
