South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 07-19-2012, 04:35 AM   #1
explosivo
Member#: 175579
2006 WRX TR
Default any hvac guys here?
basically my heat exchanger motor keeps overheating. Had the motor and the start capacitor replaced, but the motor keeps overheating. Looks like the original motor was a .9 amp 1/5hp 825 RPM and the new one is 1/5th hp 1075 RPM 1.7 amp. Could this be causing issues??
explosivo is offline   Reply With Quote
Old 07-19-2012, 10:04 AM   #2
Brianaz
Member#: 303426
2011 Sti
Silv
You need to properly match the amp draw rating on the new motor to the original motor.
Brianaz is offline   Reply With Quote
Old 07-19-2012, 11:00 AM   #3
TwinscrollGT35R
Member#: 256810
Might be able to build s simple circuit to step it down. Or just get the right part
TwinscrollGT35R is offline   Reply With Quote
Old 07-20-2012, 11:29 AM   #4
Brianaz
Member#: 303426
2011 Sti
Silv
Also is it a dual or single capacitor for compresser and fan ? Or individual for the fan motor. Also check to see if you have the proper mfd, if you don't have the correct mfd, being over or under could cause it to overheat, just another thing I thought of. I don't physically work on A/c units but if you need someone to check it out I have a few people at work that could take a look if needed.
Old 07-20-2012, 07:15 PM   #5
Whiteoutfr-s
Member#: 326754
It's overheating because it's the wrong rpm. The fan blade was designed for 825 rpm, the motor is trying to turn 1075 rpm and over amps and cuts out because of high temps. I work for air time cooling and heating out of chandler. Look us up and we can get you taken care of.
Thanks,
Travis
Whiteoutfr-s is offline   Reply With Quote
Old 07-21-2012, 11:37 PM   #6
explosivo
Member#: 175579
2006 WRX TR
Thanks for the suggestions, yeah the start capacitor was the right size, but yeah the pitch of the fan was to much for the faster RPM motor. I got the dude I bought the motor from to swap it out for an 825rpm 1/3 - 1/8 hp motor. Swapped it in along with a 7.5MFD cap and it's been working like a champ for the past two days. Looks like that was it!
