Old 07-19-2012, 10:49 PM   #1
DannyR714
Member#: 305745
2011 5DR STI
Dark Grey
Default 18x10 Rota SVN e30 fit on a 11 5dr STI w/stock suspension??
Hi everyone sorry if this question has been asked over and over i tried searching but didn't get exactly what i was looking for. I'm looking to get Rota SVN's and was wondering if i could run 18x10 with a 30 offset with just rolling the rears, stock suspension, and no camber adjustments. And also if that is possible with no rubbing would 265 would be the appropriate tire with no stretch and all. Thanks.
DannyR714 is offline   Reply With Quote
Old 07-20-2012, 12:35 PM   #2
sc00by4life
Member#: 97135
Did you even BOTHER searching??? There are 2 threads at the very top specifically for these questions.
An no you won't clear a 265 on those wheels with only rolling the rears and no camber adjustment.... If those are your requirements or wheels, stop looking at wheels that wide. It takes time and money.
Old 07-20-2012, 12:51 PM   #3
Improbus
Member#: 278439
2011 WRX 306HP/333TQ
1997 Legacy Outback EJ25
If you want zero fitment issues on the 2011 body with stock suspension the best you can do is a 18x9.5" +38 with a 255/35R18 or even a 245/40R18 if you don't mind a slight stretch. This thread is your friend.
Improbus is offline   Reply With Quote
Old 07-20-2012, 12:53 PM   #4
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Not to mention premature wear on your wheel bearings with an offset of +30. If u r looking to go 265 an 189.5 +40 or +38 offset would be more optimal and might get away with not having to roll your rear fenders at stock height.
Oops I guess u beat me to it improbus lol
trev762 is offline   Reply With Quote
Old 07-20-2012, 01:02 PM   #5
Improbus
Member#: 278439
At 18x10 +30 more than likely you will also need rear control arms to get the camber right even on the stock suspension. When you start to wander this far from the stock offset you are going to start noticing a steering difference with "numb" turn in and problems with the Scrub radius
. Again its not impossible to make these fit and people definitely do it but it takes time and money as sc00by4life said.
Old 07-20-2012, 01:05 PM   #6
trev762
Member#: 280572
2011 sti sedan
plasma blue pearl
Originally Posted by Improbus
At 18x10 +30 more than likely you will also need rear control arms to get the camber right even on the stock suspension. When you start to wander this far from the stock offset you are going to start noticing a steering difference with "numb" turn in and problems with the Video Link: http://en.wikipedia.org/wiki/Scrub_radius. Again its not impossible to make these fit and people definitely do it but it takes time and money as sc00by4life said.
Exactly the car will be always be trying to find center axis which in turn will not be a pleasure to drive
