Old 07-21-2012, 10:27 AM   #1
kayfouroh
Member#: 280113
2011 Forester
Question TPMS light flashes, then goes away, on long drives
On my 2011 Forester FB25, the TPMS light will flash for a few minutes, then turn steady for maybe 5-10 minutes, then go away for about an hour when I am driving on long trips, probably >60 minutes long. I checked each tire by hand with 2 gauges and both gauges read ~33-35psi per tire cold, which should be good. Does anyone know why this is happening? Should I bring it to the dealership?
Thanks.
kayfouroh is offline   Reply With Quote
Old 07-21-2012, 01:05 PM   #2
fbjr2003
Member#: 258846
2011 Impreza WRX
Blue Pearl
Thanks.
What's the recommended tire pressure for your vehicle? should be on your door jam if you don't know. If your tires are reading 33-35 cold like you said and your door jam says the same then I would go to Subaru and have them check. Sometimes the TPMS gets codes and they have to clear them. but it takes literally 5 min to do.
Or if your tires recommend more air (cold) then I'd say that when you're on your long trips it warms the tire up to the point that the psi is at the specific level to turn the light back off. Hope this was helpful.
fbjr2003 is offline   Reply With Quote
Old 07-21-2012, 01:15 PM   #3
kayfouroh
Member#: 280113
2011 Forester
Can't remember off the top of my head (can't remember the exact pressure either) but I am 100% sure it matched the pressure on the door panel.
What's weird is this only happens on long drives. My ~30-40 minute commute does not trigger this behavior, driving somewhat long drives (~60 minutes) does not trigger this behavior, just when I am driving for looonnnggg drives, ~6-8 hrs.
I'll call the local dealership on Monday, I guess. Thanks
Old 07-21-2012, 05:11 PM   #4
NJJer
Member#: 288369
2011 STI Limited
Not sure about this car, but some also have sensors in the spare. If so, it may be low and when it heats up from the exhaust heat coming up thru the trunk area, shut the light off when it gets in operating range.
Seen this before.
NJJer is offline   Reply With Quote
Old 07-21-2012, 05:12 PM   #5
cutty3zx
Member#: 269295
2010 Impreza Wrx
Satin White
I had that happen to me once, turned out the pressure was on the high side and long trip=higher tire pressures from friction. Just had to let a few psi out and it was all good
cutty3zx is offline   Reply With Quote
