Old 09-01-2002, 09:12 AM   #1
IceClimber
Member#: 23812
1996 Impreza
Red
Default Idle Air Control Valve: Anyone had this replaced?
Subaru dealer said that mine is the reason I get a high idle. He also said that it was a $400 job. One dealer also once told me I needed a new steering column along with about $600 of work, which my mechanic told me was a bunch of BS. He was right. I don't want to spend $400 on a 1996 Brighton Coupe with 190,000 miles on it. Any suggestions?
Meeg
IceClimber is offline   Reply With Quote
Old 09-02-2002, 03:08 PM   #2
tonytiger
Member#: 3844
1993 Legacy 1.8
I don't know how much the the IAC valve will cost, but the job is described in Haynes (lottery ) manual in about 50 words and three fotos.
I haven't got a scanner so I'm not able to send the instructions from the manual for you. It's not expencive to buy either.
I also bet here is someone who are able to help you with instructions and knowledge.
tony
tonytiger is offline   Reply With Quote
Old 09-02-2002, 03:16 PM   #3
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
The problem has already been identified by the dealer:
-Buy the part on-line [or local if you dealer will give you a competitive discount].
-Buy a Haynes or Chilton manual, [it will come in handy for other repairs].
-Do it youself in less than 5 minutes.
Albert is offline   Reply With Quote
Old 09-03-2002, 08:56 AM   #4
IceClimber
Member#: 23812
1996 Impreza
Red
Default Where to buy online?
Where might I purchase an Idle Air Valve Controller online? Thanks for the help.
Meeg
Old 09-03-2002, 01:28 PM   #5
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Default Liberty Subaru
You can get it from newsubaru.com (East Coast) or subaruparts.com (West Coast).
Also, AutoZone.com lists one for $340.
Alternatively, you can just try cleaning it with intake cleaner (or carb cleaner marked safe for O2 sensors/converters). Take it off and spray it down...
Also try cleaning you throttle body.
vvk is offline   Reply With Quote
Old 07-23-2014, 05:16 PM   #6
1greasemonkeygirl
Member#: 397076
Legacy IAC Valve
Meeg
Just the part is $400, can only imagine what it would cost with labor . I took the 1 off my car & cleaned it. Then used sea foam(read up on that). Car runs much better
1greasemonkeygirl is offline   Reply With Quote
Old 04-04-2015, 05:22 PM   #7
Kosma
Member#: 257727
1967 Impreza
I have the same problem on my 93 Impreza. Could someone please tell me where this part is? Thanks
Kosma is offline   Reply With Quote
Old 04-04-2015, 05:33 PM   #8
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
That was 12 years ago, pretty sure they took care of it by now
does this sound like a bad idle air control? subaru7717 Legacy Forum 4 03-27-2006 08:38 AM
Anyone have an Idle Air Control valve for sale? Fat Tits Tri-State Area Forum 4 08-02-2005 09:51 AM
anyone ever here of an idle air controller going bad turbocolin Tri-State Area Forum 4 02-10-2005 05:34 PM
Idle Air Controller Yotsuya Normally Aspirated Powertrain 15 06-27-2004 07:56 PM
idle air control valve, after a turbo mod mild_se7en Normally Aspirated with bolt-on Forced Induction Powertrain 1 08-10-2002 07:45 AM
