Old 07-19-2012, 12:36 PM   #1
Mstolz
Member#: 317237
Default Engine Internals 2.5 Sohc
Does Anyone Here Know Of Any Companies That Offer Internals (pistons, Rods) For The 2.5 Sohc Out Of An 04? Building The Top End And Want To Go Through The Bottom While Its Out. Any Ideas Or Information Would Be Much Appreciated. Thanks
Mstolz is offline   Reply With Quote
Old 07-19-2012, 12:38 PM   #2
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Do you google? Try twe, manly.
Old 07-19-2012, 11:33 PM   #3
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Wtf with caps on every word's first letter
Bluefoton is offline   Reply With Quote
Old 07-19-2012, 11:38 PM   #4
GrundleJuice
Member#: 165749
1982 Sex Machine
Flesh
Its One Big 3 Sentence Title
Old 07-20-2012, 10:03 AM   #5
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Except "pistons" lol
A Google search or even search of the forums will bring you more information and quicker. Try that out. There are several places to buy replacement internals. rockauto.com ... go take a look around
J.Gibbs is offline   Reply With Quote
Old 07-20-2012, 07:22 PM   #6
Mstolz
Member#: 317237
I Have To Use Caps Lock At Work... Geez!!!! Anyone Selling Used Pieces Here?
Old 07-21-2012, 02:42 PM   #7
Bluefoton
Member#: 141373
2008 2.5i-hatch -
Nope. The Classified Ads is restricted exclusively to Subaru owners who manufacture new pieces in their bathrooms
Old 07-21-2012, 03:37 PM   #8
beau13990
Member#: 259659
I don't get it. If you used Caps Lock, wouldn't everything look LIKE THIS? Does your boss like for every word to be capitalized?
As for your original question, I think that the naturally aspirated 2.5 shares a (forged) crankshaft with the WRX / STI, so you should be good there already. I don't know about the pistons, though.
beau13990 is offline   Reply With Quote
Old 07-21-2012, 03:43 PM   #9
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
I was thinking the first part but didn't wanna be that guy
And the n/a engines are sohc when the sti are dohc...
Old 07-22-2012, 02:07 AM   #10
Mstolz
Member#: 317237
Sohc heads flow better.
Old 07-22-2012, 02:19 AM   #11
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
The number of camshafts has nothing to do with whether differ engines share a crankshaft.
Counterfit is online now   Reply With Quote
Old 07-22-2012, 02:48 AM   #12
GEE-OTTO
Member#: 201277
2009 Legacy GT
The EJ25 crank is the same for all 253/5/7
GEE-OTTO is offline   Reply With Quote
Old 07-22-2012, 02:50 AM   #13
GEE-OTTO
Member#: 201277
2009 Legacy GT
Use a stock crank and rods from a WRX then get high CR pistons
Old 07-22-2012, 03:13 AM   #14
vicious_fishes
Member#: 158864
2003 SOHC destroker
crawford performance do some 9.0:1 pistons that with the lower CC's of the SOHC get around 9.5:1. add in an STI headgasket and you're near as makes no difference stock compression ratio.
then just use sti rods and you're set.
Old 07-23-2012, 01:51 AM   #15
Counterfit
Member#: 124254
"The Scoobinator"
I keep wondering whether stroker cranks for turbo motors would work with OEM or aftermarket NA pistons...
Old 07-23-2012, 10:45 AM   #16
GEE-OTTO
Member#: 201277
2009 Legacy GT
A stroker crank, forged pistons and c16
Old 07-24-2012, 04:32 AM   #17
Leviman
Member#: 326627
2006 Legacy 2.5i
Yes, absolutely. Just have to make sure the deck height ends up correct and that your compression ratio is good. You could bump compression up a bit and run premium for some more power. Also, if you're building up the bottom end, you really should get some headwork/cams done. Essentially the power is in the heads, the strength is in the internals.
Leviman is offline   Reply With Quote
Old 07-24-2012, 06:59 AM   #18
Counterfit
Member#: 124254
"The Scoobinator"
Oh it's just a pipe dream. I'll probably never have the time or opportunity to actually do it.
