Welcome to the North American Subaru Impreza Owners Club Tuesday January 27, 2015
Old 07-21-2012, 07:26 PM   #1
StackSmasher
Member#: 316928
2012 STI limited
Subaru Banner Will someone please review my logs?
Hey all, Will someone please review my logs and let me know if everything looks alright? Thanks in advance.
https://docs.google.com/spreadsheet/...l9RVEpnaXUzOWc
MODS.
Stage 1 93 oct OTS map
Perrin CBE and other stuff that doesnt effect the tune or power.
Ambient temp 101 degrees F (yikes lol)
3rd gear pull. It appears I missed redline by a bit but its pretty close.
StackSmasher is offline   Reply With Quote
Old 07-22-2012, 10:57 AM   #2
Cobb Tuning
Member#: 4803
MODS.
You have some double counts (-2.8) of fine knock learning at high load - some fine knock learning is just noise (at high load it can occur right when you lift off the throttle at the end of a run or right when shifting at that time). But, I would do some additional logs. May also just be due to the high temps, but overall it is not excessive. Everything else looks fine.
Bill
Old 07-22-2012, 12:30 PM   #3
StackSmasher
Member#: 316928
2012 STI limited
Bill
Thanks Bill. I will do another pull this afternoon and reply back.
Edit. I did a couple more pull stghis morning ambient temp was about 85 degress. I forgot to put it in Sharp so I did them in Sport mode.
There still seems to be consistent high RPM knock.
Suggestions? flash 91 octane map perhaps?
https://docs.google.com/spreadsheet/...1NwOEpINkhXbXc
https://docs.google.com/spreadsheet/...VZKVkNwd3ZmdEE
Old 07-22-2012, 06:03 PM   #4
StackSmasher
Member#: 316928
2012 STI limited
Bump anyone?
Old 07-22-2012, 08:35 PM   #5
bacalhau16
Member#: 297565
2011 WRX hatch
Try the 91 map for a while and fill up with some better gas if possible. I wouldn't drive too aggressive with this map and your current gas. Go through this tank and log again to see if that made a difference.
bacalhau16 is offline   Reply With Quote
Old 07-22-2012, 09:17 PM   #6
StackSmasher
Member#: 316928
2012 STI limited
Thanks, that's kind of what I figured the next logical step would be.
About the gas though, my car has only ever seen 93 oct Shell, and my last tank was purchased at a very high volume gas station.
However, I have been out of town for a week so the car didn't see any driving. But I don't think gas degrades that quickly ( correct me if I'm wrong of course.)
I guess I will drive around a bit and will log again on my next tank.
Old 07-23-2012, 01:08 AM   #7
bacalhau16
Member#: 297565
2011 WRX hatch
I've used shell while i was in Florida and had no issues, but you never know. Im not sure if only 1 week would weaken the strength of the fuel. I wouldn't think so.
Old 07-23-2012, 09:46 AM   #8
Cobb Tuning
Member#: 4803
You do not have any knock in these logs. Keep in mind that fine knock learning is a learned correction that is re-applied over and over (in specific load/RPM ranges around the original event(s)) until it eventually learns back to zero. So, in these logs you are simply seeing the correction being re-applied. We would need to see when those original corrections were learned, but we don't have that data in these logs.
I would go ahead and reflash the 91 octane version of the map. Then add the knock sums to your log list ("Set Data Log List" function). Don't be concerned with the values of the knock sum (they are meaningless). Try to log some WOT runs after you reflash the 91 octane map. If we see any of the knock sums increment during the WOT run, that means that a perceived knock event occurred. If you see fine knock learning without an increment in any knock sum, then that is a correction based on a prior event (all the current fine knock learning will be cleared when you reflash the 91 map).
Bill
Old 07-23-2012, 10:01 AM   #9
StackSmasher
Member#: 316928
2012 STI limited
Thanks a lot Bill. I will log a few runs when I get back in town.
