Old 07-22-2012, 06:55 PM   #1
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Default Can the a/c controls be modified?
Ok I read when you step on the gas at a certain throttle point the a/c will turn off. Is there a way to adjust this on the 02 wrx. It's been irritating me.
Old 07-23-2012, 12:20 AM   #2
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Really doubtful. I think it's driven by a WOT signal which is also used by your ECU for A/F ratio maps, you can't adjust that. Is it really that irritating? The AC cycles on-and-off anyways, it's simply a measure to prevent the torque from being robbed under WOT acceleration.. useful at low RPMs, IMHO.
The only thing that you could do is trace back a signal wire into the AC circuit to physically disable the cutoff.
Old 07-24-2012, 01:02 PM   #3
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
It's been irritating you that you read it? Or could you describe what the car is doing that is irritating you?
Side note, I haven't seen a wiring diagram that shows the ECU does anything like you are describing. My guess is that more than likely it's simply the fact that when the A/C is on, the compressor cycles on/off as needed anyway so the faster the engine spins (stepping on the throttle), the less time it needs to be on. Thus, it could give the illusion that it shuts off with throttle simply because the engine speed is increasing. I suppose it could be doing something internally since the ECU is involved in the process, but the wiring doesn't show anything out of the ordinary, and nothing in the ROM files I have seen imply that it does this either.
~T.J.
02CWRX is offline   Reply With Quote
Old 07-24-2012, 01:24 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The compressor clutch is in fact controlled by the ECU in addition to the thermal switch in the evaporator. So in addition to the normal cycling, it will cut out at WOT as well as above a certain RPM and also outside a set ambient temp range. This is done partially to maximize engine performance under hard acceleration, but also to protect the compressor from overspeed and other conditions that could damage it. Just about all AC-equipped vehicles do this as well, you really don't want to defeat it.
Old 07-24-2012, 05:49 PM   #5
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Interesting. I just wanted more a/c more of the time.
