Old 07-23-2012, 01:53 AM   #1
twistymaster
Member#: 279743
2002 WaGonWrx Hybrid
Default Replacement 01 2.5rs engine question
HI, I bought a 01 2.5 rs with a blown engine "ran out of oil, destroyed rod bearings" My Sohc heads have a recent rebuild on them and are dirty but otherwise in good shape. My question is, What engine block should I be searching for to replace this one with. ? Like what year block will mate up with these heads? I saw an 06 2.5i for cheap I was going to snag. Would I have any problems bolting my heads to this block for instance ?
twistymaster is offline   Reply With Quote
Old 07-24-2012, 01:25 PM   #2
Chaz2.5
Member#: 168181
2008 3.52 SWP 08 WRX
1999 EJ205'd RS coupe
Should be able to bolt it up without issue. Both are the EJ25 whether it be 251, 253, shouldn't make a difference., Both are NA
Chaz2.5 is offline   Reply With Quote
Old 07-24-2012, 01:56 PM   #3
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
It would work, but you'd be missing out on the AVLS goodness.
Counterfit is offline   Reply With Quote
Old 07-25-2012, 08:06 PM   #4
twistymaster
Member#: 279743
So there is no difference in the blocks? , anything Ill have to cap off ?
Message Board Statistics All times are GMT -4. The time now is 07:10 AM.
