Old 07-23-2012, 08:45 AM   #1
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
Default Please read log! Not reaching target boost.
I just uploaded my stage 2 map for my 2003 wrx with a 2004 motor in it. My mods are, tbe,dp,uppipe,crank pulley, and big tmic. I am only reaching about 14.5 psi when i am supposed to be reaching 16.5.. Should i up load a different map with a high or low waste gate?
UPDATE: heres the log
https://docs.google.com/open?id=0B6S...WI3NUM3aEtjQkk
nismopowerdqg is offline   Reply With Quote
Old 07-23-2012, 08:49 AM   #2
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
Do you have a version 2 AccessPORT (gray with color screen)? If so, I would get a data log:
Bill
Old 07-23-2012, 08:52 AM   #3
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
I have the one with the color screen and ok i will do that when i get off work!
thanks Bill!
Old 07-23-2012, 09:33 AM   #4
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
thanks Bill!
I would also download the latest v310 map from the maps section at the cobbtuning.com site. Use the AccessPORT Manager software to transfer the map from your computer to the AccessPORT and then reflash that map to the car (do not real-time flash it). The newer maps are more consistent.
Bill
Old 07-24-2012, 03:30 PM   #5
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
hey bill, i haven't uploaded the new map yet but i did take a data log of my car. this is my first time trying to use google documents so if you cant open it please let me know. but as you can see im not reaching max boost pressure, and if you see anything else out of skew let me know.. i did not reach red line bc i was approaching a turn.
I do have a aftermarket tmic and catless uppipe
thanks!
Old 07-25-2012, 09:11 AM   #6
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
please readdddd
Old 07-25-2012, 09:57 AM   #7
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
thanks!
Can you use google docs to convert it to google docs format so that there's a preview?
I would go ahead and reflash the newest map (v310). The boost tune is different on the new maps anyway, so any logs with the old tune when you are going to run the new tune are irrelevant. We want to see how the car reacts on the new version maps and go from there.
Bill
Old 07-25-2012, 05:52 PM   #8
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
I uploaded v3.10 and my idle went crazy and threw some code for rough idle. I had to go back to v3.00. Any thoughts?
Old 07-26-2012, 08:13 AM   #9
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
That is highly unusual. What was the code? Where did you download the map from? What exact map did you use? Did you reflash the map (connect the green test mode connectors and initialization connector and select reflash when changing maps) or did you realtime flash the map?
Bill
Old 07-26-2012, 08:42 AM   #10
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
Bill
i downloaded from your website, also i dont remember the exact code because i was stuck 30 mins from my house and was more concerned about reflashing so i could get back home. and i did the real reflash (connected green wires and initialization connector as well).
Old 07-26-2012, 08:48 AM   #11
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
and i used stage 2 93 map
Old 07-26-2012, 11:35 AM   #12
Cobb Tuning
NASIOC Manufacturer
Member#: 4803
I would try reflashing it again (from your home) and try to get the code that pops up if it occurs again. That definitely shouldn't happen.
Bill
Old 07-26-2012, 11:41 AM   #13
nismopowerdqg
Member#: 312580
2010 Impreza WRX
Satin White Pearl
Ill do it one day when its cool outside its gonna be in the 100's for the next few days. Ill keep u informed.
Message Board Statistics All times are GMT -4. The time now is 04:34 AM.
