Old 07-23-2012, 10:12 AM   #1
markbot
Member#: 240552
2011 Subaru WRX
Default Stage 2 datalog check
Finally was able to do a proper data log on my 2011 running OTS Stage 2 93oct. link
There was some knock mid-run, but it seemed to be learned away. Is this an issue?
Thanks.
markbot is offline   Reply With Quote
Old 07-23-2012, 11:53 AM   #2
bacalhau16
Member#: 297565
2011 WRX hatch
As long as that continues to go down in value, you will be alright.
Have you used the Launch Control on your car at all?
bacalhau16 is offline   Reply With Quote
Old 07-23-2012, 12:31 PM   #3
Cobb Tuning
Member#: 4803
Thanks.
You have a single count of feedback knock at high load - not something you generally want to see. What are all your mods?
Bill
Old 07-23-2012, 01:23 PM   #4
markbot
Member#: 240552
2011 Subaru WRX
Bill
Nameless Performance turbo-back. Otherwise stock.
Edit: Here is a snippet from the same log (I forgot to turn logging off after the first run.) Not quite as long as the first run, but it did not have any feedback knock.
Thanks for taking a look, Bill.
Old 07-23-2012, 01:24 PM   #5
markbot
Member#: 240552
2011 Subaru WRX
I have not. I don't have any need for it, and I want to save the transmission/clutch as much as possible.
Old 07-24-2012, 09:26 AM   #6
Cobb Tuning
Member#: 4803
I would go ahead and take some additional logs over time - see if that feedback correction from the earlier log was a fluke or not. I would also consider switching gas brands, especially if you are using a "no-name" brand of grass. Some have better luck with the so-called "top tier" gas brands.
Bill
