Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 07-23-2012, 11:47 PM   #1
Devc
Member#: 218437
1992 Lego SS/Stagea
Default Whats this sound like to you, knocking noise.
So engine is an ej22t shortblock with almost 300,000miles on the pistons and bores with new rings and std sized bearings. Heads are Ej25d. Only 40 miles or so since the block was split this started.
Engine is at operating temp during video, noise is there when cold, but alot quieter. the knocking is consistent, no squieking and happens between say 1500rpm and 3000rpm unlike a rod knock,
could this be main bearings?
or alot of piston slap given the mileage?
What else?
I cut open the oil filter, there was some debris in there, may bave been from it being apart, I changed the oil and will run it around the block again and cut open the other filter.
I know, I cheaped out on this, but I'm only in the short block for like $150, but its biting me in the ass.
Devc is offline   Reply With Quote
Old 07-24-2012, 02:11 AM   #2
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
These engines are noisy. I don't hear ANYTHING wrong with this.
If you're really concerned... leakdown/compression test.
Are you experiencing a loss of power? stutter??
Sounds fine to me.
DHRDAN is offline   Reply With Quote
Old 07-24-2012, 03:24 AM   #3
eg33GC
Member#: 206851
99 V4
EJ20K RS
for sure some bad slap, but it is hard to tell beyond that
eg33GC is offline   Reply With Quote
Old 07-27-2012, 02:34 PM   #4
Devc
Member#: 218437
1992 Lego SS/Stagea
Talked to some reputable aquiantances around town, we are guessing severe piston slap. Makes sense because it is a 470,000 kms on bores plus a hone and the original pistons put back in lol.
Either way the motor is allready torn down to the shortblock for inspection and assuming theres no grooves in the walls it will be getting .040 over forged wisecos.
