Old 07-24-2012, 12:17 PM   #1
Grimdajow06
Member#: 324758
2015 WRX
ISM
Default 09 2.5i suspension
Does anyone know if there's any advantage to install a stock 09 suspension on to a 2.5i? Would it improve handling?
Grimdajow06 is offline   Reply With Quote
Old 07-24-2012, 01:47 PM   #2
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
Stock 09 suspension from what?
And wrong forum. Try this one:
Brakes, Steering & Suspension
NH8991 is offline   Reply With Quote
Old 07-24-2012, 01:49 PM   #3
Fredward
Member#: 322518
2008 2.5i Hatchback
1995 Mercedes-Benz S600
You'll probably get more responses if you update your profile with what you drive...
A stock '09 2.5i suspension on a '09 2.5i would be... Well... Stock...
Fredward is offline   Reply With Quote
Old 07-24-2012, 05:44 PM   #4
Grimdajow06
Member#: 324758
2015 WRX
ISM
My fault meant to say putting stock 09 wrx suspension on a 09 2.5i
Old 07-25-2012, 11:17 AM   #5
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
Sounds expensive... for small gains. A swaybar and good tyres will do a LOT...
Old 07-25-2012, 01:34 PM   #6
NH8991
Member#: 197937
2016 Golf R
+1, especially if you still have the stock Bridgestone RE92 (brace yourself for the impending slide into a ditch at the slightest hint of moisture ) tyres.
Sways are probably the best bang-for-the-buck mod for the 08+ cars, but the 09 WRX rear bar is only 16mm (though still a drastic improvement compared to the 0mm bar on the 2.5i), personally I would go for the STI 18mm or the Rallitek 19mm bar.
One thing the sways won't do is manage the front-to-rear pitching, so if you want to retain stock ride height the 09 WRX springs/struts are a reasonable way to go, they have decent spring rates (and obviously matched damping) compared to the 2.5i.
This is the route i'm going, just haven't got around to the install yet.
Old 07-26-2012, 12:31 PM   #7
Grimdajow06
Member#: 324758
2015 WRX
ISM
Thx, the reason I asked is because I purchased some stock wrx springs/struts from another member for a pretty good price so I wanted to no if I'd see any gains
