Old 06-07-2016, 03:32 PM   #1
mariokerdj
Member#: 327329
2002 Impreza WRX
Question misfire problems help cams BC 272
hi i need help my car is wrx 2002 i have BC cams, adjustable cam gears, spring kit all BC, my car show misfire the cods are p0301, p0302, p0304.
the spark has changed 2 weeks ago have iridium bkr8 the sparkplug is black i set the rpm in 850 and i cant eliminate this codes i know if i desactivate in the map but i dont like to do this i need an other solution help me please or tell me what i need to do..???
mariokerdj is offline   Reply With Quote
Old 06-07-2016, 06:30 PM   #2
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
Were you actually tuned for these cams or just half assing this?
Old 06-07-2016, 11:12 PM   #3
hijinks
Member#: 440839
2003 WRX
Originally Posted by mariokerdj View Post
dis
Just wondering... what do you do with all of that extra time you save by typing a 'd' instead of a 'th'?
hijinks is offline   Reply With Quote
Old 06-09-2016, 10:33 AM   #4
mariokerdj
Member#: 327329
2002 Impreza WRX
Have a Nice Day? this values have
i have tactrix i set de revs in 850 and 950 to A/C
the primary open loop have this values
the base timming have this values
Old 06-09-2016, 10:37 AM   #5
mariokerdj
Member#: 327329
2002 Impreza WRX
Thumbs up
sorry, now you can help me...???
Old 06-09-2016, 12:07 PM   #6
Samurai Jack
Member#: 21145
2002 Enemy of Aku
How long have you had these cams installed before you started getting the P030x codes?
Samurai Jack is online now   Reply With Quote
Old 06-15-2016, 11:40 AM   #7
mariokerdj
Member#: 327329
2002 Impreza WRX
Default .
the cams installed in december finale the codes began appearing in mid January if activated the celfix disappear but is not right i try changin the spark but the same error
Old 06-16-2016, 08:16 AM   #8
SHOfast
Member#: 99083
02 impreza
I think you need to work on the tune. Sorry I am not more help, your images are not loading.
SHOfast is offline   Reply With Quote
Old 06-16-2016, 09:09 AM   #9
Samurai Jack
Member#: 21145
2002 Enemy of Aku
Agreed, as was now mentioned a couple of times by others ...
If you have been running for few weeks before the P030X codes started, you probably need a proper tune.
... and, for your sake and everyone else's when you ask for help, please use proper sentences and punctuation. Hard to tell when one sentence ends and another begins
Old 06-17-2016, 01:55 AM   #10
mariokerdj
Member#: 327329
2002 Impreza WRX
Have a Nice Day? .
sorry i know my english its bad.
and yes a couple of weeks work i dont know why know check engine its the code p030x I need someone to give me an orientation, What I can do for this...!!!
Old 06-17-2016, 06:24 AM   #11
Mahtava
Member#: 292449
02 wrx
95 gf5
try idle around 1200 or so with a 13.5 afr
Mahtava is offline   Reply With Quote
Old 06-17-2016, 06:29 AM   #12
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
Did you shim the valves according to what the BC cams required or did they just get bolted in and not reshimmed? Why the adjustable cam gears? Did you shave too much off of your heads?
PSolbergfan is offline   Reply With Quote
