Old 07-24-2012, 09:06 PM   #1
adarikeOG
Member#: 281429
2004 Stg 2 REX Wagon
Default Just installed DP and flashed STG 2, datalog check please!
Hey everybody. I just installed a Invidia Catted Divorced Wastegate Downpipe, in addition I have a 06 STi Catless Up-Pipe, SR-S Type-RE catback exhaust, Cobb SF Intake with air box, and an Mishimoto IC Hose Kit. My car was tuned with an AP to Stage 1 until today, when I reflashed to Stage 2 91 octane (v. 3.10). Here is a link to a datalog I just recorded right after installation of my DP. I noticed my DAM is at 15, and I know it should be at 16. Other than that, I don't know too much about how to read a log (I have watched Cobb's videos on making data logs and how to interpret them) If anybody could check it out and let me know how it looks that would be great! Thanks!
https://docs.google.com/spreadsheet/...2RkQVlGR2FOY3c
adarikeOG is offline   Reply With Quote
Old 07-24-2012, 10:31 PM   #2
BigRob74
Member#: 305107
2016 GT 5.OHH
DIB
lots of fine knock is what is see
BigRob74 is offline   Reply With Quote
Old 07-24-2012, 10:47 PM   #3
bluemax189
Member#: 137405
2011 WRX 6spd
GTX3076r
try the 91 octane map to see if the knock goes away.
bluemax189 is offline   Reply With Quote
Old 07-25-2012, 10:43 AM   #4
Cobb Tuning
Member#: 4803
Your DAM has dropped to 15, which indicates that a series of knock events has occurred. There are common mechanical problems with these older cars that typically involve fueling. What I would do is drive around normally (no heavy throttle for now) for about a tank of gas without reflashing any maps or resetting the ECU. Then take a look at your long-term fuel trims via live data (A/F Learning 1 A, B, C, D). That will usually tell us if there is a problem if any of those trims are well outside of +/- 5% (but it takes some driving for them to populate accurately).
Bill
Old 07-25-2012, 06:05 PM   #5
adarikeOG
Member#: 281429
Bill
I will definitely do that. If the values stay outside of +/- 5% what sort of problem might that indicate? I know MAF failures are fairly common with these cars, but I think mine is still fine. I clean it at every oil change. Thanks for all the help!
Adam
Old 07-25-2012, 06:06 PM   #6
adarikeOG
Member#: 281429
Also, I completely forgot to mention, car has 121000 miles on it.
Old 07-26-2012, 09:11 AM   #7
Cobb Tuning
Member#: 4803
Adam
Extreme values can indicate intake tract leak, bad/tired MAF sensor, bad front o2, or other mechanical fueling issue.
Bill
