Old 07-25-2012, 09:51 AM   #1
berdugo
Member#: 163108
07 EuroDM STi 2.5L
Default Running meth pump using ecu duty cycle
Does anyone here controls the meth pump from a PWM output of stand alone ecu? I'm thinking of using MoTec M800's output to control the meth pump. Will use solid state relay to switch the ground of the pump with a switched +12V supply voltage from the battery.
berdugo is offline   Reply With Quote
