Old 07-25-2012, 02:11 PM   #1
rightbrainnow
Member#: 327193
Default transmission question
im looking at a couple subaru impreza outback sports. one is a 99 with 95k and the other is an 02 with 147k. both same price. had a buddy with an 02 wrx and told me about the infamous glass transmission. does the 02 outback sport have the same tranny? I checked out the site listed in the faq for newbs, and i cant see any difference really. trying to figure out if a car thats 4 years newer is worth the trade off in an extra 50k miles on engine...if it has that bad tranny though, makes decision a little easier
http://www.cars101.com/subaru/impreza/impreza2002.html
thanks
rightbrainnow is offline   Reply With Quote
Old 07-27-2012, 01:38 PM   #2
rightbrainnow
Member#: 327193
bump...anyone?
Old 07-27-2012, 02:58 PM   #3
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
same casing, different gearing. different rear differential final drive most likely. I have not committed final drive ratios to memory, you will need to look those up. They are readily available on this site somewhere.
I believe the clutch is a different configuration as well push vs pull. You will also need to look up that information, which is also available on the site.
Sir-Knight is offline   Reply With Quote
Old 07-27-2012, 03:14 PM   #4
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
The wrx transmission doesn't become a problem unless you beat on it or go past 300 hp. even if it were the same you shouldn't have a problem.
