Old 07-25-2012, 04:25 PM   #1
ToneWrx02
Member#: 239095
2002 Wrx
Default Jdm ej205 in bugeye wiring question
So everything is put into my bugeye. Every bolt is tighten and plugged in. I prdered the engine harness since i sold mine, but i said hey what the hell i try to start it. It would try to start then die right away immediately. Is this because of the jdm engine harness being different?
Its the only ting i could ink of why it isnt turning over for longer. Not trying to drive it just check to see condition of motor.
ToneWrx02 is offline   Reply With Quote
Old 07-25-2012, 04:37 PM   #2
ToneWrx02
Member#: 239095
2002 Wrx
Just thought maybe its the gas since its been sitting for almost two years so il drain the tank.
Old 07-26-2012, 01:42 AM   #3
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
That and give it just a little bit of revs (2000 rpm) to help it keep going for a minute or so then allow it to idle. Make sure oil pressure is fine before doing so!
Marnix is offline   Reply With Quote
Old 07-26-2012, 03:27 AM   #4
ToneWrx02
Member#: 239095
2002 Wrx
I tried but couldnt drain it all, but most of it i did. Then i put alittle abit pf gas and it helped it very very little. So il put more gas and see what it does after i install the harness.
Old 07-26-2012, 02:06 PM   #5
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
:: shakes his head in saddness::
DHRDAN is offline   Reply With Quote
Old 07-26-2012, 02:25 PM   #6
eg33GC
Member#: 206851
56 Belair
Pro Street
get out
try looking for a vacuum leak, and make sure you have the maf plugged in
eg33GC is offline   Reply With Quote
Old 07-26-2012, 09:40 PM   #7
ToneWrx02
Member#: 239095
2002 Wrx
I got the car running and it wouldnt idle with the maf plugged in i believe, couldnt do much testing because there was small sparka near the cluch cylinder and so i turned the car off, after that it wouldnt start back up or crank at all. So im going to check ground wires and the starter tomorrow.
I put some octane booster in the tank to get rid of the small amount of bad gas in there and put about 2 gallons of 91 to help it out.
Old 07-27-2012, 07:01 AM   #8
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
You have a pre-2002 EJ205 in a bugeye?
If It's a 2000-2002, you should look at the EJ207 owner's thread. You have a very similar situation with what is there.
As far as wiring harness that is on the engine, keep the JDM one.
You can repin, if needed. Also, download the wiring diagram of your EJ205, it will have a clear description of the pins in the main connectors.
Then you can trace the pins for the JDM harness.
In the EJ207 you don't have to repin anything anyway, so I doubt you have to with the 205.
You have AVCS, but most likely TGV's too.
Are you using the JDM ECU that comes with this engine?
Old 07-27-2012, 01:23 PM   #9
ToneWrx02
Member#: 239095
2002 Wrx
I already installed the usdm engine harness, im not going to use avcs. I called my tuner and he can fix the small things
Old 07-27-2012, 01:25 PM   #10
ToneWrx02
Member#: 239095
2002 Wrx
And its the 2001 jdm ej205 so its a direct swap just swap over the engine harness from what my tuner and everybody said
Old 08-13-2012, 11:10 PM   #11
WrexTi
Member#: 225723
2002 Wrx ej207 stg 2
Did you install the usdm cam gears? You have to do this in order for this swap to work if you're using the usdm ecu. Hope that helps.
WrexTi is offline   Reply With Quote
Old 08-25-2012, 12:01 AM   #12
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
Its a shame to not use a jdm ecu with avcs. Much less work and a better result then using usdm cam gears.
RS_to_WRX_swap is offline   Reply With Quote
Old 08-25-2012, 08:13 AM   #13
ToneWrx02
Member#: 239095
2002 Wrx
I know but i didnt have the ecu or wiring
Old 08-25-2012, 08:13 AM   #14
ToneWrx02
Member#: 239095
2002 Wrx
Also the jdm cams work
Old 08-27-2012, 11:52 PM   #15
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
You can find the ecu's around. Im using a v7 jdm sti ecu tuned with open sorce and it works great. The wiring is no big deal.
Old 08-30-2012, 12:11 AM   #16
ToneWrx02
Member#: 239095
2002 Wrx
Problem is im moving to Sweden and giving the car to my father, im just fixing it för him im just doing smäll things to it to make it more reliable and give it a better look.
If i Wasnt moving it would be the first thing i would Do is get a jdm ecu and wire it haha
