Welcome to the North American Subaru Impreza Owners Club Friday October 28, 2016
Old 07-25-2012, 06:49 PM   #1
Member#: 117454
2005 FXT PDX Stg II
2015 Kia Optima SXL
Default Changing knock sensor and bolt broke in half...
What should be a routine fix just went really bad. It's already hard to get in that area and the bolt snapped in half while trying to unscrew it, leaving half of the bolt still screwed in. With no way to drive the car without being able to secure the sensor what can I do to get the rest of the bolt out and also what size bolt do I need to replace it.
Local_Skater is offline   Reply With Quote
Old 07-25-2012, 07:02 PM   #2
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Are there exposed threads to grab onto? You can always try a bolt extractor.
Old 07-25-2012, 07:38 PM   #3
Member#: 294461
2006 San Remo Wagon
Under construction
Gotta pull the intake manifold off to get it. Not the end of the world. Trust me when I say it will be easier in the long run than trying to kludge it out with everything intact.
cal_look_zero is offline   Reply With Quote
Old 07-27-2012, 06:07 PM   #4
Member#: 276321
x2 take the intake off
if you can get a stud remover on there it's worth a try. Best bet is take the intake off for sure. Remember aluminum reacts differently, meaning I wouldn't use heat. A blunt punch and a firm rap with a hammer should loosen the threads up enough to get it out.
REED FLEMMMMING is offline   Reply With Quote
