Old 07-25-2012, 07:00 PM   #1
VisBits
Member#: 300773
08 STI
Black Pearl
Default Plugging wideband sensor into gauge harness causes odd electrical problems.
Hi Guys,
I just installed the Perrin dual pod gauge setup and wired my gauges into the cars harness hear the dimmer switch.
I spliced the orange leads from the gauges (headlight toggle) to the purple lead on the dimmer button.
I spliced the white and red onto the brown with white stripe of the fuse block (12V Power and Ignition).
The boost gauge works perfectly and has no issues, the headlights toggle it just fine, however if I connect the AFR gauge everything is fine until I plug the actual wideband sensor into the gauge harness. My rear wiper starts running and the headlight leveling motors turn on and stay on.. If I unplug the sensor everything goes back to normal.
Any ideas? I have everything grounded to a lug in the fusebox area.
Referenced this for wiring: http://www.scoobymods.com/showthread...009-12055.html
VisBits is offline   Reply With Quote
Old 07-26-2012, 12:56 AM   #2
02CWRX
Member#: 196013
2002 WRB WRX
EJ207 6-Speed
What gauges are you installing? I assume the car is an 08 STi?
~T.J.
02CWRX is offline   Reply With Quote
Old 07-26-2012, 04:42 PM   #3
VisBits
Member#: 300773
08 STI
Black Pearl
Prosport AFR and Boost. Yes 08 sti.
Old 07-28-2012, 10:28 PM   #4
VisBits
Member#: 300773
08 STI
Black Pearl
Turns out the boost gauge had a short internally and was causing the circuit to be finicky, it quit today and the AFR guage works perfectly. Boost gauge does not function at all even wired directly to the battery. These pro-sport gauges seem iffy.
Message Board Statistics All times are GMT -4. The time now is 11:24 AM.
