Old 07-25-2012, 08:00 PM   #1
1122bugeye
Member#: 296857
SRP
Default Front tires cupping!! Need help!!
Ok so here is the deal. My tires are fairly new and recently I have noticed that they are cupping on the outside. There is probally 5k on these tires. I'm hoping it's a alignment issue. But I'm looking for other peoples opinion! ThAnks!!!!
1122bugeye is offline   Reply With Quote
Old 07-25-2012, 09:21 PM   #2
scooby4u
Member#: 324722
2004 Impreza WRX
Toe and balance issue most likely.
scooby4u is offline   Reply With Quote
Old 07-25-2012, 10:05 PM   #3
sc00by4life
Member#: 97135
Cupping is typically a sign of blown struts.
Old 07-26-2012, 03:58 AM   #4
1122bugeye
Member#: 296857
SRP
Coil overs are fairly new. I'm hoping a mix of under inflated and alignment....... Possible???
Old 07-26-2012, 04:20 AM   #5
sc00by4life
Member#: 97135
If it was an alignment issue, and the tires were indeed cupping, it usually happens in the rear.
what tires are they? could just be cheap tires (which are more prone to this).
could also be: wheel bearing, or loose strut bolts. other than that - its a sign of springs/shocks being bad.
what coils are they? could be cheap parts/poor valving/poor spring rates.
could also be a balancing issue.
cupping happens from the tire bouncing up and down, so there are only limited reasons for this to be happening.
Old 07-26-2012, 09:26 AM   #6
1122bugeye
Member#: 296857
SRP
Well I wAs told that too much toe in I believe could cause it on the out side I believe. Could be toe out.... But the car came with cx- racing coilovers. They are pretty stiff. And hold the road nice. But sits pretty low.. I shook the whole car down yesterday. Nothing loose. All bolts are tight. This is just weirs to me because my last set wore perfectly even last summer....
Old 07-26-2012, 03:52 PM   #7
sc00by4life
Member#: 97135
Toe causes even wear, typically on the inside.
Cupping is almost exclusively bad shocks (in your case cheap coilovers) or poor quality tires.
Old 07-26-2012, 10:07 PM   #8
Web Foot STi
Member#: 39086
2004 STi
Poor balance can also cause cupping. You would typically notice the vibration long before significant wear though.
Web Foot STi is offline   Reply With Quote
Old 07-27-2012, 01:25 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
not enough neg camber
Old 07-28-2012, 09:27 PM   #10
1122bugeye
Member#: 296857
SRP
It was the alignment!!! Toe was-.25 on each wheel!!
Old 07-28-2012, 09:33 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
what about the REST of the numbers???
the rest is just as important
ya GOTTA have some negative camber in front or ya gonna eat the outsides of the tires
Old 07-29-2012, 12:22 PM   #12
sc00by4life
Member#: 97135
just because toe was off - doesn't mean its going to solve your problem. we'll see in time, but i'm positive it aint the toe. ive never seen toe cause cupping, and i've had toe off on my car by 1*.
like scotty says - post the rest of the alignment specs.
Old 07-29-2012, 02:11 PM   #13
1122bugeye
Member#: 296857
SRP
ok hear are the rest of the numbers
left caster 3.65 final 3.94
right caster 4.12 final 4.35
L camber -.30 final -.27
R camber -.10 final -.10
L toe .25 final 0.00
R toe .30 final 0.00
Old 07-29-2012, 08:12 PM   #14
Uncle Scotty
Member#: 16200
OK buy Nates beans
that isnt enough negative camberya NEED at least -1* up front...and -1.5* is better or ya just gonna corner on the sidewalls
Old 07-29-2012, 10:27 PM   #15
sc00by4life
Member#: 97135
Yes whoever aligned your car has no idea what they are doing.
Take it somewhere else and have it realigned. You need more neg camber.
