Old 07-28-2012, 10:34 PM   #26
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Originally Posted by cucamelsmd15 View Post
Ive always been told the RA-1 and NT-01 were the same. :shrug:
I wont waste the money on the R888s again though.
Agreed. I always heard the RA-1 and NT-01 were the same compound. Would explain the similar consistency. The R888's fall off a cliff after about 3/4 of there life.
Old 07-29-2012, 11:38 PM   #27
jamal
Member#: 71875
98 Legacy GT
my wheels fit
I was under that impression as well but heard r888=nt01 under good authority. Or maybe they're all the same lol.
jamal is offline   Reply With Quote
Old 07-30-2012, 07:22 AM   #28
REX8
Member#: 24038
Always heard the compound sof the RA1 and NT01 are the same. They certainly behave very similarly, with their only real distinctions being down to tread pattern/depth (hence the unshaven heat buildup in the RA1s, and their advantage in the rain). But their grip level, heat cycling characteristics, etc. are almost exactly the same.
That's not true with the R888 compared to the NT01. No way are they made from the same compound IMHO.
Old 07-30-2012, 07:47 AM   #29
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Agree. The R888s I had are/were distinctly different than the NT01s.
cucamelsmd15 is offline   Reply With Quote
Old 10-04-2012, 11:31 PM   #30
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 627/484 2015 BRZ
considering some r6's... this is for the track, not autoX or drag. i was told that a 255.35.18 in a r6 would be 10mm wider than a dunlop star spec 255.35.18?? (which is what i have..)
A Fatal Ode is offline   Reply With Quote
Old 10-05-2012, 12:09 AM   #31
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
I use Hoosier R6 275-35-18
bhhamblin is offline   Reply With Quote
Old 10-05-2012, 01:32 AM   #32
A Fatal Ode
Member#: 243616
2010 WRX 336/384
like 'em? any complaints?
Old 10-05-2012, 01:48 AM   #33
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
No complants this far. Had them heat cycled when I purchased them from Tirerack. They have lasted the whole season and have some tread left.
Old 10-05-2012, 10:35 AM   #34
Rokkit
Member#: 84181
NASA #530 GTS2
Yeah I use either Hoosier R6 or a Goodyear Eagle RS (road race compound). 245x40x17
The Hoosiers will heat cycle out before they cord... prob loose 1-1.2 seconds after about 6-8 heat cycles. Goodyears hold up a bit better... wear is nicer and sidewalls are stiffer (which I like) but if you're not going for tenths I wouldn't worry about the heat cycles.
Rokkit is offline   Reply With Quote
Old 10-05-2012, 04:11 PM   #35
tazswing
Member#: 63767
2009 OXT 5-spd
2011 STi hatch
I just picked up some R1R, 275/40R17 to run on my GR. I have to run a wet/dry tire here in Oregon since the track days I hit are early fall and spring which means high possibility of being wet. I can post up a review since I will be heading out on them Oct. 21st. Hopefully they are not as squirmy as described above!
tazswing is offline   Reply With Quote
Old 10-05-2012, 06:31 PM   #36
A Fatal Ode
Member#: 243616
2010 WRX 336/384
6-8 heat cycles on the r6's? Is there something that's more like 15?
Old 10-06-2012, 02:09 AM   #37
A Fatal Ode
Member#: 243616
2010 WRX 336/384
what about the Z214's?
Old 10-06-2012, 01:08 PM   #38
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
a6s run pretty consistent until cords. my bfg r1s are proving to be the same
rjrutzky is offline   Reply With Quote
Old 10-06-2012, 05:18 PM   #39
A Fatal Ode
Member#: 243616
2010 WRX 336/384
i heard that the A6 was an autoX tire and the R6 was for circuit use?
anyone have an opinions of the hankookz214's?
http://www.tirerack.com/tires/survey...wdp=N&showcm=N
Old 10-06-2012, 07:33 PM   #40
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
You can use an A6 or V710 as a track day tire. I use V710s on my S2000 and know a lot of other guys that do the same with 370Z's, Mustang Cobra's, Miatas, M3's and STi's. I don't do enough events to chord a set of tires before they heat cycle out. A lot of guys who time trial with buy a fresh set of V710s, time trial on them until they get slow, then get a new set and use the old slow ones for practice.
Two of my favorite track day tires are the V710s and NT01s. Yokohamas are garbage. Bridgestone RE11's are fantastic street/track tires as are the Hankook RS3's. I'd like to try the Hankook with the C91 compound but I'd have to buy a set of 18" wheels.
eastcoastbumps is offline   Reply With Quote
Old 10-06-2012, 09:39 PM   #41
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
a6 are great for circuit. for real high track temps and longer races, you might consider the others (r6, etc).
Old 10-06-2012, 11:26 PM   #42
A Fatal Ode
Member#: 243616
2010 WRX 336/384
what i do is about 3 track days a year at my current rate.. each track day is 5 20 minute sessions. and then that's it for the track "season" for me. so that equates to 15 heat cycles right? ..sorry, i'm new at this.
what i'd like is a nice r compound that'll last a "season" for me.
Old 10-07-2012, 01:17 AM   #43
CGMDan
Member#: 127883
'09 C63 AMG '99RSTi
'05 CGM STi - RIP
A6's for a tracktire??? I've heard of using them for time attack where you need a grippy tire without being able to heat them up, but not as a general track day tire. Heck, in AutoX people are considering spraying them after 1 run on a 70* day. Seems to me they'd get too hot and greasy in just a few laps time.
CGMDan is offline   Reply With Quote
Old 10-07-2012, 05:39 AM   #44
Autolight
Member#: 311699
R888 is great!
Autolight is offline   Reply With Quote
Old 10-07-2012, 09:12 AM   #45
JMK508
Member#: 115420
Its like a STI.....
but it doesn't break
I have had nothing but great experiences with the NT01's. And you can drive them DD if you have to. I would not recommend any rain use though.
JMK508 is offline   Reply With Quote
Old 10-07-2012, 09:36 AM   #46
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
Well now you have. I've won 8 races this year on them. They are good start to finish in a 35-40 minute race. Much faster than R6 (at least a second per lap)
Old 10-07-2012, 09:39 AM   #47
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
NT01.
Old 10-07-2012, 10:36 AM   #48
cucamelsmd15
Member#: 122980
Originally Posted by Autolight View Post
R888 is great!
No.
I dont know anyone who isnt running the A6 if they can. One of the C5 Mafia had Hoosier send him R6s instead of A6s by mistake. The result was 1.5 seconds slower at Road Atlanta.
Youre the only person Ive ever heard say they are fast to the cords though. Most everyone else I know says that after 10 HCs or so, they drop about a 1-1.5 seconds, which in some cases is still faster than an R6, but definitely not prime tire type lap times. :shrug:
Old 10-07-2012, 10:54 AM   #49
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
No.
Those C5 guys win them so often, they don't know what cords are They do slow down some, but still faster than R6 before cords in my experience. And after 10HCs or so, they are close to cords depending on where you are running them, heat, etc.
Old 10-07-2012, 11:09 AM   #50
A Fatal Ode
Member#: 243616
2010 WRX 336/384
nt-01's not on tirerack? hmm, k... must actually do some foot work.
