Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 07-23-2012, 03:50 PM   #1
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
Default Getting my car going
My car was dyno tuned by AMS for stage 2, I now installed 650 DW injectors, Blouch 16gxt, and walbro 255 fuel pump. What exactly should I change tO make the car safe to drive and get to AMS to be tuned. I have my laptop and a tactrix cable. I have already read my ecu and have the ROM. I changed the injector scale to 650 already.
05stage2 is offline   Reply With Quote
Old 07-23-2012, 05:55 PM   #2
quazimoto
Member#: 70395
Injector scaling and latency . Set WGDC to zero
Old 07-24-2012, 03:58 PM   #3
05stage2
Member#: 307545
2005 wrx
2.1 stroker on e85
Just got the car running and i logged a few things...
I haven't changed the latency yet because i'm not sure what i should set it at and such. Is the car safe to drive around a little?
Old 07-25-2012, 09:17 AM   #4
quazimoto
Member#: 70395
That is not a datalog. Make an actual datalog and include a Learning View screenshot. DW should be able to provide you with the latency values. They should be somewhat close to stock with the 650cc injectos.
Old 07-25-2012, 11:02 PM   #5
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
Iff you're just driving to the tuner, set max WGDC to 0 set injector scaling around 650 (whatever gets the closest to zero in the MAF tab), andd just drive it there. You should be close enough to not really worry about it for a short distance.
