Old 07-26-2012, 05:57 PM   #1
Kcanz13
Member#: 283833
2005 wrx
silver w/ cf hood
Default o2 sensor out of stock wrx exhaust
So I need to get out my old o2 sensor but I have tried everything to get this SOB out and nothing has worked. The only thing i haven't tried is heat. Any good suggestions?
Kcanz13 is offline   Reply With Quote
Old 07-26-2012, 06:02 PM   #2
Kcanz13
Member#: 283833
2005 wrx
silver w/ cf hood
It is in the stock down pipe btw
Old 07-26-2012, 06:59 PM   #3
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Heat. Soak it in PB blaster over a couple of nights (Like SOAK the o2, several times. Then use a torch to heat the metal around the bung. Sometimes trying to tighten it will break the hold, then you can get it out easier.
cal_look_zero is offline   Reply With Quote
Old 07-26-2012, 11:07 PM   #4
GrundleJuice
Member#: 165749
keep in mind, you will destroy it by using heat and/or pen oil, in case you were planning on using it again.
Old 07-27-2012, 10:49 AM   #5
Kcanz13
Member#: 283833
2005 wrx
silver w/ cf hood
So i won't be able to use it again? Im trying to use it again and save some cash but if its a lost cause then so be it. Is there anyway that I can use it again?
Old 07-27-2012, 11:43 AM   #6
Sir-Knight
Member#: 73636
2007 Impreza 2.5i SE
newport blue pearl
wrx o2 sensors don't work on 2.5is as far as I know.. different wire configuration.
Sir-Knight is offline   Reply With Quote
Old 07-27-2012, 04:40 PM   #7
Kcanz13
Member#: 283833
2005 wrx
silver w/ cf hood
I have a 2005 wrx. 2.0T.
Old 07-27-2012, 06:00 PM   #8
GrundleJuice
Member#: 165749
Usually heating the sensor without the sensor being in the hot exhaust stream will harm or destroy it. Don't know why exactly but they are sensitive. Any foreign substance like a penetrating oil or even water is harmful to the objective end of the sensor. If you keep that part dry you might be ok. When Removing a stubborn or old o2 sensor its a good idea to at least have a spare since chances are good that it will be junk.
Side note: this is the n/a powertrain forum. For future inquiries about the vehicle in question I would post in the correct forum as you will get better feedback.
Old 07-27-2012, 10:24 PM   #9
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Are you using an actual oxygen sensor wrench? With a breaker bar on it you should be able to break them free easily. I just got mine out after 180k miles of new england weather with not too much force
J.Gibbs is offline   Reply With Quote
Old 07-30-2012, 03:09 PM   #10
Kcanz13
Member#: 283833
2005 wrx
silver w/ cf hood
I have tried that, minus the breaker bar. Ill have to try it out
Old 07-31-2012, 01:08 PM   #11
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
try out the correct forum, this space is for Non-Turbo vehicles.
Samirr76 is offline   Reply With Quote
Old 07-31-2012, 02:29 PM   #12
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
Raceface already brought that up. It may be the wrong forum but its an easy question to answer, that's why I did. If its that big of a problem mods will move it
OP, get an offset style 7/8" (22mm) oxygen sensor socket. It takes a 3/8 drive breaker bar. Can be had for like 6 dollars at harbor freight. Sears carries them too for like double the money. The offset gives you more torque to bust those old sensors free and can get into tight spots
Old 07-31-2012, 03:15 PM   #13
J.Gibbs
Member#: 312107
1998 LowFoz
Glacier White
This is what I use:
Notice the wrenches aren't even breaker bars. My foz is a 98 with 180k and both O2s came out without too much muscle, plus the sensors were stock!
Old 07-31-2012, 04:11 PM   #14
awd1927
Member#: 118667
2015 WRX (CVT)
CWP
yea like mentioned above ...soak in pb blaster and a good breaker bar ...you just need the right leverage
awd1927 is offline   Reply With Quote
