Old 07-27-2012, 08:06 PM   #1
jsathern
Member#: 284445
04 impreza wrx
black
Default log question
Code:
Time Engine Speed (RPM) Manifold Absolute Pressure (PSI) Air/Fuel Learning #1 (%) Air/Fuel Correction #1 (%) Throttle Opening Angle (%) Mass Air Flow (g/s) Knock Correction (BTDC) Air Flow Sensor Voltage (V) Manifold Relative Pressure (PSI) Primary Wastegate Duty Cycle (%) Air/Fuel Sensor #1 Current (mA)
0 2494 5.08 7.81 2.34 5.49 10.32 0 1.74 -9.43 0 -1
187 2529 14.22 7.81 12.5 84.71 40.25 0 2.56 -0.29 0 0.25
376 2510 15.09 7.81 3.91 100 36.58 0 2.5 0.58 0 -3.5
630 2544 16.11 7.81 3.13 100 39.53 0 2.56 1.6 0 -1.13
822 2641 17.27 7.81 0 100 46.83 0 2.66 2.76 0 -0.38
1014 2654 18.14 7.81 0 100 45.52 0 2.72 3.63 0 -6.88
1326 2697 19.44 7.03 0 100 53.1 0 2.8 5.22 0 -6.75
1650 2767 20.89 6.25 0 100 57.16 0 2.84 6.38 0 -7.25
1832 2818 22.64 5.47 0 100 65.74 0 2.96 8.13 0 -6.38
2106 2871 23.94 4.69 0 100 71.98 0 3.04 9.43 0 -9
2308 2952 26.26 3.91 0 100 83.19 0 3.26 12.48 0 -13.75
2500 3008 28.44 3.13 0 100 92.68 0 3.34 14.66 0 -16
2750 3098 30.62 2.34 0 100 97.45 0 3.38 16.11 0 -16
2936 3134 31.05 2.34 0 100 99.59 0 3.36 16.54 0 -14.75
3118 3208 31.05 2.34 0 100 99.55 0 3.38 16.54 0 -15
3360 3320 30.91 1.56 0 100 102.43 0 3.44 16.4 0 -14.75
3554 3400 30.76 0 0 100 107.3 0 3.44 16.25 0 -14.25
3736 3437 30.76 0 0 100 106.63 0 3.42 16.25 0 -14.75
3928 3495 30.62 0 0 100 108.3 0 3.46 16.11 0 -14.63
4140 3588 30.91 0 0 100 112.61 0 3.5 16.4 0 -14.38
4342 3664 31.05 0 0 100 119.42 0 3.54 16.54 0 -14.38
4574 3702 31.05 0 0 100 116.26 0 3.54 16.54 0 -14.5
4756 3782 31.2 0 0 100 125.11 0 3.62 16.69 0 -14.88
4960 3858 31.34 0 0 100 128.43 0 3.64 16.83 0 -14.75
5152 3898 31.34 0 0 100 130.93 0 3.66 16.83 0 -14.63
5334 3966 31.34 0 0 100 129.82 0 3.66 16.83 0 -14.75
5575 4008 31.2 0 0 100 134.62 0 3.7 16.69 0 -14.38
5759 4094 31.2 0 0 100 132.63 0 3.64 16.69 0 -14.5
5942 4157 31.05 0 0 100 136.36 0 3.7 16.54 0 -14.88
6124 4206 31.05 0 0 100 142.9 0 3.76 16.54 0 -14.88
6306 4283 31.05 0 0 100 142.6 0 3.74 16.54 0 -14.63
6498 4313 31.05 0 0 100 144.4 0 3.82 16.69 0 -14.63
6680 4386 31.2 0 0 100 147.69 -3 3.8 16.69 0 -15
6905 4440 31.2 0 0 100 156.91 -3 3.9 16.69 0 -14.75
7096 4456 31.2 0 0 100 156.6 -3 3.88 16.69 0 -15
7278 4559 31.2 0 0 100 156.6 -3 3.84 16.69 0 -14.75
7470 4590 31.2 0 0 100 160.44 -3 3.9 16.69 0 -15.13
7714 4641 31.34 0 0 100 162.33 -3 3.92 16.83 0 -14.88
7896 4702 31.34 0 0 100 160.41 -3 3.9 16.83 0 -15
8078 4741 31.49 0 0 100 168.71 -3 3.96 16.98 0 -14.75
8260 4786 31.49 0 0 100 164.63 -3 3.94 16.98 0 -14.75
8516 4848 31.49 0 0 100 169.4 -3 3.98 16.98 0 -15
8706 4899 31.49 0 0 100 169.74 -2 3.98 16.98 0 -15
8888 4950 31.34 0 0 100 169.4 -2 3.96 16.83 0 -14.75
9140 4990 31.2 0 0 100 176.56 -2 4.02 16.83 0 -14.88
9325 5050 31.2 0 0 100 177.58 -2 4 16.69 0 -14.88
9517 5088 31.34 0 0 100 179.29 -2 4.02 16.83 0 -14.63
9755 5137 31.34 0 0 100 183.26 -2 4.08 16.83 0 -14.88
9933 5197 31.34 0 0 100 183.26 -2 4.06 16.83 0 -14.75
10115 5237 31.34 0 0 100 187.28 -2 4.08 16.83 0 -15.13
10297 5271 31.2 0 0 100 184.36 -2 4.08 16.69 0 -14.75
10546 5342 31.05 0 0 100 186.91 -2 4.06 16.54 0 -14.75
10727 5396 31.05 0 0 100 190.92 -2 4.08 16.54 0 -14.63
10915 5439 31.05 0 0 100 189.1 -2 4.12 16.54 0 -15.25
11107 5462 31.05 0 0 100 193.12 0 4.14 16.54 0 -14.88
11370 5519 31.05 0 0 100 190.2 0 4.14 16.54 0 -14.88
11553 5584 30.91 0 0 100 194.94 0 4.14 16.4 0 -15
11735 5601 30.76 0 0 100 196.06 0 4.16 16.25 0 -15.13
11917 5639 30.76 0 0 100 196.4 0 4.16 16.25 0 -15.13
12099 5708 30.62 0 0 100 194.58 0 4.14 16.11 0 -15
12322 5734 30.62 0 0 100 196.4 0 4.18 16.11 0 -14.75
12506 5734 30.47 0 0 100 198.3 0 4.18 15.96 0 -15.13
12691 5818 30.33 0 0 100 196.45 0 4.16 15.82 0 -15
jsathern is offline   Reply With Quote
Old 07-27-2012, 08:07 PM   #2
jsathern
Member#: 284445
04 impreza wrx
black
is this good or bad car has intake and full turbo back 3" exhaust and mbc
Old 07-27-2012, 08:22 PM   #3
Black94Snake
Member#: 274499
1994 5.8T Cobra
565rwhp @ 10psi
Repost your log to Google docs. None of us really want to sort through that heap of crap you posted.
Black94Snake is offline   Reply With Quote
Old 07-29-2012, 11:57 AM   #4
jsathern
Member#: 284445
04 impreza wrx
black
K i couldnt remember where to post it
Old 07-29-2012, 08:50 PM   #5
jsathern
Member#: 284445
04 impreza wrx
black
k found it here it is. k im new to this so plz let me know whats wrong and whats the parameters supposed to be at thanks
https://docs.google.com/spreadsheet/...FVrVTFuQXJsZkE
k just made it public forgot to ..
Old 07-30-2012, 07:48 PM   #6
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
You got -2 to -3 degrees of knock from 5000-5900. That's not good
Slimsti is offline   Reply With Quote
Old 07-31-2012, 02:08 PM   #7
VFXWRX
Member#: 310146
2002 vf39'd wrx
psm (sold)
Log IAM, and post a Learning View snapshot. That will give a better overall picture of the health of your engine.
VFXWRX is offline   Reply With Quote
Old 07-31-2012, 04:39 PM   #8
jsathern
Member#: 284445
04 impreza wrx
black
How do you do that fairly. New to logging
Old 07-31-2012, 04:45 PM   #9
VFXWRX
Member#: 310146
2002 vf39'd wrx
psm (sold)
Assuming you're using romraider to log, you can just add IAM to your log values. Learning View is a free diagnostic software available here:
http://www.romraider.com/forum/topic2772.html
Old 08-02-2012, 09:22 AM   #10
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
Also get rid of All the O2 sensor stuff and log Final fueling Base(calculated) and ignition total timing. What I am guessing is going on is your running a bit leaner then you should be @ WOT(just a guess based on O2 voltage). Also post your mods.
endrswrd is offline   Reply With Quote
Old 08-02-2012, 03:26 PM   #11
jsathern
Member#: 284445
04 impreza wrx
black
I did post them its got an aem intake and turbo back 3" exhaust no cats or resonator anf an mbc and yea i was told its prolly running lean. I cannot get romraider to connect to my car to save my life the buttons are greyed out. Btw i have a vagcom cable could that be y??
Old 08-02-2012, 04:11 PM   #12
VFXWRX
Member#: 310146
2002 vf39'd wrx
psm (sold)
You were tuned for these mods right? Also you need an openport2 cable.
Old 08-03-2012, 01:19 AM   #13
jsathern
Member#: 284445
04 impreza wrx
black
No i got the car as is except the cat back it had an sti exhaust from dp back also before i got the mbc my stock boost guage was only reading .05 mpa? ?? Hered thats not stock.
Old 08-03-2012, 01:50 PM   #14
VFXWRX
Member#: 310146
2002 vf39'd wrx
psm (sold)
Stock boost should be around 14psi, you just turned up your boost to around 17 without changing fuel tables. Not to be dramatic, but you are in serious danger of blowing up your engine if you don't 1. stop modding, and 2. get a good tune.
Old 08-04-2012, 12:53 AM   #15
jsathern
Member#: 284445
04 impreza wrx
black
K well i need some obe to help me change my fuel tables anyone around bonneylake puyallup area willing to help out
