Old 07-28-2012, 05:38 PM   #1
Subie22
Member#: 133355
06 06 WRX Limited
15 Tacoma SR5
Default Data Logs (Boost Oscillation)
Alright so I finally decided to data log my car. I've been experiencing boost oscillation and not always hitting peak boost. If anyone can help, I'd appreciate it!
2006 WRX
First map is a simple 2nd and 3rd gear normal driving pull to show the boost oscillation.
https://docs.google.com/spreadsheet/...pSEpaT0E#gid=0
Second is a pull from around 2.5k up to red.
https://docs.google.com/spreadsheet/...EcW1VNEE#gid=0
Third is the idea as the second.
https://docs.google.com/spreadsheet/...lTGlqUnc#gid=0
Like I said, any help is appreciated.
Subie22 is offline   Reply With Quote
Old 07-29-2012, 09:55 AM   #2
Cobb Tuning
Member#: 4803
2006 WRX
That doesn't look bad at all - especially the WOT pulls. You can try loosening the wastegate arm a bit (there are various tutorial threads on this on Nasioc) to see if that helps. Are you feeling the oscilliation at all as far as driveability?
Bill
Old 07-29-2012, 12:31 PM   #3
Subie22
Member#: 133355
06 06 WRX Limited
15 Tacoma SR5
Bill,
The oscillation is extremely noticeable when it's present. It will eventually level out after about 3-4 surges, but passing someone could be quite interesting at times. Is it possible an exhaust leak could cause this? Would I benefit from your 3-port ebcs?
-Dom
Old 07-30-2012, 08:40 AM   #4
Cobb Tuning
Member#: 4803
Bill,
-Dom
I would reflash the fuel economy map as a test. This will disable boost control and allow you to see if the oscillation still occurs in this case. If it does, it may indicate a mechanical issue. May not be conclusive if it doesn't do it then, but at least worth a try.
Bill
Old 07-30-2012, 02:20 PM   #5
Subie22
Member#: 133355
06 06 WRX Limited
15 Tacoma SR5
Reflash the real time map, correct?
Old 07-30-2012, 04:20 PM   #6
Cobb Tuning
Member#: 4803
A real-time flash is fine for this particular test.
Bill
Old 07-30-2012, 09:43 PM   #7
capelani06
Member#: 190859
03 wrx
I Recently replaced my stock wrx TMIC for the STI TMIC and ran a data log. not sure what to make of it. I'm running the stock turbo with a catless turbo back exhaust, CAI, and BOV on the stage 2 93oct map from cobb version3.10
capelani06 is offline   Reply With Quote
Old 07-31-2012, 09:08 AM   #8
Cobb Tuning
Member#: 4803
Best thing to do is to get a data log as described in the video below (if you can do so safely). You can post the log at google docs (make sure to convert it to google docs' format and set the permissions to public) and then link it here. Keep in mind that our OTS maps for the 02-05 WRX are only compatible with the Cobb SF or stock intake. Using other intakes may cause issues without a custom tune.
Bill
Old 07-31-2012, 11:00 AM   #9
Subie22
Member#: 133355
06 06 WRX Limited
15 Tacoma SR5
Bill
And this is why I keep buying your products. Talk about customer service.
Thank you, sir. I'll give this a try
