Old 07-28-2012, 06:13 PM   #1
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
Default 2012 Windshield Washer Spray Pattern
On my 2012 Impreza
My Windshield washer spray pattern does not seam to hit the drivers side very effectively.
Is anyone else having a similar issue?
Is there away to adjust the spray pattern or direction with these washer nozzles?
Thanks!
ZionZR2 is offline   Reply With Quote
Old 07-28-2012, 07:16 PM   #2
53x12
Member#: 206332
Just take a safety pin or paper clip and stick it in the nozzle holes and adjust accordingly. At least that is how it was on my old car. Have you looked in the owners manual yet?
53x12 is offline   Reply With Quote
Old 07-29-2012, 02:23 AM   #3
enfinityx
Member#: 326440
2012 impreza
i got mine adjusted when i took it in for first oil change (mine was lower on the driver side than on the passenger side and didnt hit the top), sprays great now.
enfinityx is offline   Reply With Quote
Old 07-29-2012, 03:02 AM   #4
jr0bb5
Member#: 315353
2012 Impreza Sp Prem
5MT OBP/DGM
I seem to have the same problem too. Do you know how they adjusted it?
jr0bb5 is offline   Reply With Quote
Old 07-29-2012, 08:18 AM   #5
leeden
Member#: 41654
2005 Impreza WRX STi
2012 Sport Limited
I also have the same problem.
leeden is offline   Reply With Quote
Old 07-29-2012, 10:53 AM   #6
monkeyracer
Member#: 308583
2015 Forester XT
Crystal Black Silica
I asked my dealership about this, and they say that is how it is designed. If you look at the nozzle and the cowl, it is designed to point more toward the center of the windshield.
Something about the aerodynamics of the spray at 75 mph or the fact that the drivers side wiper blade is 10 feet long...
I don't have a problem with it actually cleaning the windshield, but I did notice this when I first sprayed the washer.
monkeyracer is offline   Reply With Quote
Old 12-02-2012, 06:34 PM   #7
ScoobyCO
Member#: 236205
2013 ImprezaSport5MT
Ice Silver Metallic
Originally Posted by ZionZR2 View Post
On my 2012 Impreza
Thanks!
I was having a similar issue where my drivers side nozzle was pointed way too low. Turns out the nozzles ARE adjustable. Firstly, you do NOT want to use the pin adjustment method as is acceptable for older vehicles because the nozzle orifices are specifically shaped to produce a fan spray and are made of easy to damage plastic.
How to adjust:
Tools: Small 1/8" flat screwdriver
Above and below the orifices are horizontal slots that fit a small flat screwdriver perfectly. Insert your screwdriver in either slot and carefully adjust the nozzle up/down and left/right, as needed. You should feel and see the nozzle rotate in its housing.
Test your work, re-adjust, and enjoy!
ScoobyCO is offline   Reply With Quote
Old 12-03-2012, 10:05 AM   #8
jay25RS
Member#: 4273
2015 Taco
& 2015 Legacy Ltd.
How to adjust:
Tools: Small 1/8" flat screw driver
Test you work, readjust, and enjoy!
Good information! Thank you!
jay25RS is offline   Reply With Quote
Old 12-03-2012, 05:41 PM   #9
goregasm
Member#: 331656
2012 2.0i
Marine Blue Pearl
How to adjust:
YOU ARE SEX
goregasm is offline   Reply With Quote
Old 12-03-2012, 06:23 PM   #10
ZionZR2
Member#: 319990
2012 Imp Prm 5D CVT
Dark Grey Metallic
How to adjust:
Thanks Very Much!!
I think I have dialed in just right now!!!
Old 12-03-2012, 06:25 PM   #11
finklejag
Member#: 318622
2012 Impreza
My drivers side was hitting low. I moved it up a little. It sprays in the center of the windshield now.
finklejag is offline   Reply With Quote
Old 12-03-2012, 09:26 PM   #12
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
Thanks, going to try this too.
pkL is offline   Reply With Quote
