Old 07-28-2012, 11:42 PM   #1
mayorofsc
Member#: 255666
2005 WRX STI
Default windshield washer fuse
Hey everyone, so my 2005 STi blew a fuse when I tried to use the windshield washer and the wipers stopped mid stroke. I replaced the fuse that controls the wipers and as soon as I turned the key the fuse blew again. I think there may be a short in the motor? Has anyone else had a similar experience or any knowledge as to what could be the culprit? Thank you in advance for any advice you can give.
mayorofsc is offline   Reply With Quote
Old 07-29-2012, 10:30 AM   #2
Twitch819
Member#: 327467
Look for an open wire, that would cause high resistance and pop a fuse
Twitch819 is offline   Reply With Quote
Old 07-30-2012, 12:48 PM   #3
LIChuck
Member#: 266122
2007 WRX Limited
UGM
Ha Ha Ha. Open wires and high resistance don't pop fuses. Fuses are protection from over current not under current, otherwise every time you turned a switch off the fuse would blow.
Check for a short in the wire supplying power to the wipers.
LIChuck is offline   Reply With Quote
Old 08-02-2012, 05:59 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
To find out if the short is within the motor see if you can disconnect the motor easily and then turn on the switch. If the short is gone then chances are the short is within the motor. Though there may be something with the circuit design that may complicate that kind of test.
Cougar4 is online now   Reply With Quote
