Old 07-29-2012, 09:20 PM   #1
turbo970
Member#: 325644
1992 legacy
Default do the subaru's need 14.4 volts to run right
well found out that my alt wasn't putting any juice out. i was wondering if the Subaru electrical needs 14.4 volts in order to run right. it will start up with a freshly charged battery but then stall out. and if i let it sit over night i have to let the starter to crank a while before it will fire up
turbo970 is offline   Reply With Quote
Old 07-29-2012, 09:22 PM   #2
ppayer38
Member#: 234407
04 Self-tooned
STi
No, between 13.7-14.2 is the operating range and mine runs around 13.8-14 with no issues....
ppayer38 is offline   Reply With Quote
Old 07-29-2012, 09:46 PM   #3
turbo970
Member#: 325644
1992 legacy
then my alt is bad cuz all my system is getting is 12.33 from the battery. no wonder theres weak spark and starting issues
Old 07-29-2012, 09:49 PM   #4
ppayer38
Member#: 234407
04 Self-tooned
STi
Yes... If it charges fine(check voltage while running @ the battery) then the alternator is good and doing its job...
If it doesn't start back up or has a slow start issue it is the battery not holding the charge and load the car puts on it
Old 07-29-2012, 09:55 PM   #5
turbo970
Member#: 325644
1992 legacy
i put my multi meter at the battery after i got it started and it read 12.55 at first and started to drop. when i shut the cat off it was reading 12.33 volts so the alt is bad in my book
Old 07-29-2012, 10:11 PM   #6
ppayer38
Member#: 234407
04 Self-tooned
STi
You are correct sir! Might wanna search to see if there are any horror stories on Advance/Auto Zone replacments so you don't waste money/time on sonething that'll die quickly...
I only say this because of my old DSM had to have a OE alternator or it would die no matter what
Also you can get a higher output version just for the extra room in amps
Old 07-29-2012, 10:20 PM   #7
turbo970
Member#: 325644
1992 legacy
well my choices are auto zone car quest and napa and i'm on a budget.
Old 07-29-2012, 10:42 PM   #8
ppayer38
Member#: 234407
04 Self-tooned
STi
Well do a little research and I believe you can use a different model alternator for higher loads rating
Old 07-29-2012, 11:01 PM   #9
turbo970
Member#: 325644
1992 legacy
you mean like a new modal of legacy or using one off a forester or impreza
Old 07-29-2012, 11:03 PM   #10
ppayer38
Member#: 234407
04 Self-tooned
STi
Like off an STi, forester, or impreza...
Old 07-29-2012, 11:47 PM   #11
THE Rubasu
Member#: 325861
1990 legacy wagon
color=FE
no your car doesnt have the same connectors as the new ones. your obd 1 dude. i usually try to hit up a junk yard and look for the newest stock subaru alternator from the same model years. the go for around 20 to 30 bucks. auto zone is around 110
THE Rubasu is offline   Reply With Quote
Old 07-30-2012, 01:07 AM   #12
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
This is the PRE-2002 factory turbo forum. What year model car do you have? Depending on year, JDM WRX and STI's have higher output alternators then their same year impreza domestic equivalents. Find a rebuild shop. You can have your alternator tested and if need be rebuilt to the same or better electrical output.
I had mine done 2 years ago. Cost about $150 at the shop I took it to. Before you take it to a shop go through the basics.
Clean your battery terminals and the ends of your battery cables. A battery terminal cleaner is $2.99 . After you clean the battery terminal ends put some dielectric grease on the battery terminals and the battery cable ends.
Check the accessory belt. It should neither be too loose or too tight.
Check your grounds. Everything electrical in your car needs a good ground connection to work. Alternator, starter, battery, Ignition, everything. Corroded grounds dont work. People on EBAY make madmoney selling grounding kits because people are not smart enough to clean their factory grounds. USE: wire brush. wd40. wipe clean. clean cable ends, clean bolt threads use dielectric grease on cable ends afterwards to improve conductivity and prevent future corrosion. If an overachiever sand clean the paint around the area of the bolthole.
Check the terminals on your alternator for corrosion. If found then clean .
TommyAtomic is offline   Reply With Quote
Old 07-30-2012, 12:44 PM   #13
THE Rubasu
Member#: 325861
1990 legacy wagon
color=FE
he has a first gen turbo leggy
Old 07-30-2012, 01:23 PM   #14
TommyAtomic
Member#: 257043
1993 JDM WRX Wagon
Yeah I'd check the markings on the alternator to see if its a Mitsubishi alternator. Most of the Mitsubishi alternators were high output. If its actually the problem I'd just get it rebuilt by a reputable alternator/starter shop.
You might also look up the model online using the markings off the alternator and verify the wattage. If your going to replace it dont replace it with a lesser output model.
