Welcome to the North American Subaru Impreza Owners Club Saturday October 22, 2016
Old 07-30-2012, 12:26 PM   #1
Member#: 205629
'04 v7 207 WRX
Dull version of JBP
Default Headlight confusion.
So for the past few months my headlights have been acting very strange.
What I have gathered from the past few months of observation is as follows.
With the headlight switch on the column switched on to just the low beams the passenger side low beam is bright (as it should be). Meanwhile the driver side high and low beam are both glowing a feint orange. When I push the lever on the steering column to engage the high beams only the passenger side high beam comes on, but the passenger side low beam also stays on and bright.
Fogs are unaffected thus far.
Things I have replaced to attempt to fix the problem.
1.Socket for headlight on driver side.
2.Both relays in the junction box under the hood.
3.Both the headlight and fog light switch that are behind the glove box.
~ I checked the ground locations that I knew of connected to the front harness. Cleaned them and tightened them back down.
~Also considering replacing the switch on the steering column.
I hope someone on here has the electrical knowledge to help. I really don't want to go to a dealership for fear of the cost.
If it will help I will take a few pictures.
Thanks for reading.
BbugWag is offline   Reply With Quote
Old 07-30-2012, 01:33 PM   #2
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Check the driver side headlight fuse in the engine fuse box.
