Old 01-31-2013, 10:52 PM   #76
mod maniac
Member#: 300551
2002 FOZ STI 2.34
Fullers Garage
I am running a 2002 wrx 2.1 with a 92.5 bore. I ported the heads and installed kelford 199-e cams with bc springs and retainers. It has modded stock injectors, tomei elh, meth, fp td06-20g, sti tmi, tbe, ported throttle body and tvg deleates. I was only making 325 325 but my six speed got here yesterday and my 20g blew up. So it's time to go blouch dom 2.5 xtr. I hope to see closer to 400 whp. Oh and it was reving to 7.5k.
Old 02-01-2013, 08:58 AM   #77
banny sti
Member#: 118815
Quick update on mine, basic spec 2.35, avcs heads, billet wheeled 0.82 GT35R and a syvecs ecu mapped on 99ron + 20% meth 2.1 bar
Power graph
Boost graph
banny sti is offline   Reply With Quote
Old 04-02-2013, 06:30 PM   #78
Calikid
Member#: 157491
03' JdmSti Hybrid
Emeral Green Pearl
I am in the process of joining this club.. Can't wait.
Calikid is offline   Reply With Quote
Old 04-02-2013, 10:54 PM   #79
Dr. octagon
Member#: 171127
GDA BW 8375 SOLD
Thanks for checking in, this is a good thread
Dr. octagon is offline   Reply With Quote
Old 04-03-2013, 08:08 PM   #80
sube-trex
Member#: 97577
2001 IS 300
Results..
sube-trex is offline   Reply With Quote
Old 04-05-2013, 07:48 PM   #81
Calikid
Member#: 157491
03' JdmSti Hybrid
Emeral Green Pearl
Thanks. Can't wait for it. Cosworth stroked 2.2 v7block/v8heads.. Cams/meth/Ewg/gt3076r/+1mm valves/springs,guides,retainers. all kinds of goodies . plus tons of head work will keep you guys updated. Parts being ordered this week.
Old 10-10-2013, 07:32 PM   #82
martynj
Member#: 188947
My own Cosworth 2.1 stroker now running a bit of laughing gas.
Graph shows with and without Nitrous, 75hp jets running at 50% duty through its Alcatek ecu progressive nitrous system.
martynj is offline   Reply With Quote
Old 10-10-2013, 07:44 PM   #83
2000subie
Member#: 207638
2004 WRX
Yellow
Too bad the graph is in shoot out mode. That is basically crank hp if I remember correctly.
2000subie is offline   Reply With Quote
Old 10-10-2013, 08:50 PM   #84
v8upsetr
Member#: 179447
07 OBP Sti
MSPT Tuned Camed fp RED
I believe shoot out mode is true whp no cf added
v8upsetr is offline   Reply With Quote
Old 10-10-2013, 09:12 PM   #85
2000subie
Member#: 207638
2004 WRX
Yellow
http://forums.nasioc.com/forums/show....php?t=2155706
Read the first two post, and it shows that the windows based dyno dynamics show crank hp.
Old 10-11-2013, 12:51 AM   #86
kakarot09
Member#: 182375
08 Sti
Wrbm
Here we go with the dyno argument again. Seems like it's almost every day.
kakarot09 is offline   Reply With Quote
Old 10-11-2013, 01:21 AM   #87
Juks
Member#: 108163
2015 WRX, 2005 STI
Impressive...makes you wonder why more people aren't doing this.
Juks is offline   Reply With Quote
Old 10-11-2013, 11:33 AM   #88
Screw your v8
Member#: 363565
02 WRX
Rally wrapped
im literally days from dropping in my new 2.1 built by boxer4racing
EJ205 Stroker Build 2.1L
blouch 18g-xt
grimmspeed tmic
EJ205 Block Set -New OE Subaru
BoresInspected, Bored to 92.5mm & Machine Honed
New SubaruEJ257BlackNitride Crankshaft
New K1 Technologies Rods
Custom CP 8.7:1CR 92.5mm2.1L Stroker Pistons - Forged
ACLRace Series Main& RodBearings With Coating
OE Subaru11MM OilPumpAssembly
FullyRemanufactured Cylinder Heads
Valve-trainProfessional Installed& ValvesAdjusted
Subaru EJ205Engine Gasket Kit
OE SubaruMulti-Layer Head Gaskets
Killer B Oil Pickup Tube
NGK SparkPlug-Heat Range 7-Subaru 2.0L
Mishimoto Low Temp Thermostat
Gates Racing Timing Belt
New OEM TimingBelt Components including T-Belt Tension
Assembly Adjuster +roller assy.
OEMWater Pump
Final Assembly& Intake/Exhaust ManifoldPorts Sealed
GrimmSpeed Electronic Boost Control Solenoid 3-Port -Subaru
Borla Header for WRX & STi
MAWComposite TGV
ARP Head StudKit forDOHC 2.0 & 2.5 liter
ARP MainBolts / BlockBolts
Castrol 5w30 Motor Oil 5qt.
Mahle Oil Filter for Subaru
Genuine Subaru Gasket Oil Pan CrushRing
GrimmSpeed TurboOutlet Gasket
ExedyStage 1 OrganicHeavyDutyClutch kit
Mishimoto Silicone InductionHose
Mishimoto Silicone Ancillary Hoses
BrianCrower Valves& Springs
Genuine Subaru Cooling SystemConditioner
GSC P-D 02-052.0L WRXS1 Cams 270/266
Rebuilt transmissionfor 5-speed with larger GT gears & upgraded bearings.
Shot Peened gear set
gonna tune on 93oct
any of you 2.1 guys having knock issues?
i read alot about it in the threads, but since you guys are putting up numbers i thought i'd ask?
Screw your v8 is offline   Reply With Quote
Old 10-12-2013, 02:48 AM   #89
hummelsubaru
Member#: 220153
'05 WRX JBP WFC#207
GTX3076 ViPec V44
EJ207 Manley 2.2 kit (2.1xxL)
T20C701 Spec-C case with AVCS heads
Manley 92mm pistons 8.5:1
Manley Turbo Turf I beam rod
OEM 12 STI Crankshaft 79mm
8,000rpm fuel cut
BC Valve, Spring and Titanium Retainer
Power Division GSC Stage 2 Camshaft 272 Degree
ACL Spun Bearings and Main Bearings
12mm Oil Pump
ARP Head Bolt
DW 1000cc Top Feed EV14 Injectors
AEM Fuel Reguator
DW 301 300L/H Fuel Pump
Garrett GTX3076R 102mm Anti-Surge Inlet with .82 Hotside
Tial 44mm External Wastegate
Aquamist HFS 6 Water/Meth Injection Kit
Howerton Engineering Two Gallon Twin Tank with Pump Cooling Fans
Local fuel
24psi
419whp/390wtq
hummelsubaru is offline   Reply With Quote
Old 10-12-2013, 11:45 AM   #90
Fat Boy P1
Member#: 223176
2000 560 BHP P1
Blue, of course...
2.1 CDB
Nitrided oem EJ 257 crank,
Cosworth pistons,
14mm studs,
K1 rods,
non avcs ported and polished heads
Jun/ RCM race cams (272/ 10.4)
Inconel valves,
RCM double valve springs, titanium retainers, etc,
12 mm oil pump,
Baffled sump
Catch can
6 speed Dccd spec C gearbox
R180 plated rear diff and rear axle
Exe - tc coilovers
Eibach 24mm f&r sway bars
Super pro bushes all round
Alcon/ prodrive 330mm calipers, performance friction 2 piece rotors up front
Brembo 290mm rear
Md 321v non billet
Hyper flow monster FMIC
RCM 340 l/hr in tank fuel pump
740 injectors
3" rcm decat from turbo back @ 26 psi /97 Ron gas no additives
P1 2 door classic weight 2800 lbs.
The engine can rev higher than the dyno trace but it was left at 7500 rpm. Previously ran it at 2 bar, but 1.8 was fine for now as this engine is coming out shortly (see below) and anyway in a P1 it's pretty mental. Built for track day use.
Uk style dyno graph ie. at crank.
My car is currently at the shop with an EJ 22 based 2.34 stroker going in and a rotated gt3582 billet going on
Fat Boy P1 is offline   Reply With Quote
Old 10-12-2013, 01:55 PM   #91
blubug_768
Member#: 324962
02 WRX
I'm gonna be building up my engine soon, but I see a lot of incorrect engine displacement claims for strokers, the numbers for an ej20:
75mm crank 92mm bore 1994cc
75mm 92.5mm 2016cc
75mm 93mm 2037cc
79mm 92mm 2100cc
79mm 92.5mm 2123cc
79mm 93mm 2146cc
I bet its been mentioned before
What does it take to actually get 2.2l out of an ej20?
blubug_768 is offline   Reply With Quote
Old 10-12-2013, 02:41 PM   #92
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
8,000rpm fuel cut
12mm Oil Pump
ARP Head Bolt
AEM Fuel Reguator
Local fuel
24psi
419whp/390wtq
Can you post the graph please!
Old 10-12-2013, 05:46 PM   #93
martynj
Member#: 188947
Crap conditions at our local strip today meant a very poor 11.16 1/4 with a 2.1 second 60ft but with a 143mph terminal
Old 10-13-2013, 09:07 PM   #94
Screw your v8
Member#: 363565
02 WRX
Rally wrapped
Guys,
I will post dyno results from build in a couple of weeks.
Motor and tranny going in week after next.
Break in- check out- tune-dyno the week after.
More strokers plz!
Old 10-14-2013, 04:43 AM   #95
hummelsubaru
Member#: 220153
'05 WRX JBP WFC#207
GTX3076 ViPec V44
okay, i will post up later for yous.
Old 11-05-2013, 07:53 AM   #96
[JT]
Member#: 218435
2001 18g'd Rs Coupe
2 doors less whores
How would you go about stroking a 205 to a 2.2 or even a 2.3 liter?
Might be considering a stroker build on my 205 since my crank shaft may possibly be bad.
[JT] is offline   Reply With Quote
Old 11-05-2013, 09:33 PM   #97
jura11
Member#: 255146
2001 2002 WRX Wagon
WR BLUE
Here are our results
Engine:
2.35L SBR JDM WRX with AVCS built by [email protected] Racing:
EJ22T Stroke'd to 2.35L
RCM Wiseco Pistons
Carrillo Pro A Beam Rods
ACL Race Bearing sets:big end and main bearing set
KillerB baffled sump plate/windage tray
Twinscroll Sump
OEM 11mm Oil pump and water pump
14mm Headstuds
Cosworth Stopper HG
79mm Subaru V8(EJ257) Nitrided Crankshaft
Gates Kevlar timing belt kit
OEM Subaru gasket set
Oil: Millers Nanodrive 10-60
Heads:
JDM Spec C Big port heads(S204)
CDF Vernier Pulleys(Exhaust side)
Kelford V2-199-C
Kelford KVS109-STI springs
Supertech SIVN-1010 36.00mm(Std Size)
Supertech SEVN-1010 32.00mm(Std Size)
Oil system:
Setrab/Mocal Oil cooler with Goodridge hoses and Mocal Thermostatic Sandwich plate
KillerB Baffled sump plate
Twin scroll Sump
Baffled 3-port Oil Catch Can
Fuel system:
ID1000cc injectors with Fuel Lab FPR and Fuel Lab Billet Fuel Filter
Fuel Swirl/surge pot fitted in boot with Sytec Fuel filter and 044 fuel pump including the teflon fuel lines and AN fittings
Modified WRX CDF Parallel Fuel Rails
Braided Fuel lines with AN fittings
340LPH HRC Fuel Pump
Induction/Turbo:
Spec C Inlet manifold custom powder coated
Custom made Twisted/Rotated kit with Screamer pipe
ScoobyClinic GT30 .63AR Billet
RCM 260mm Tall Filter
RCM 100mm Spun Aluminium Induction Trumpet
3port Porsche boost solenoid
Delco 3 bar Map sensor
NOS Sniper wet system(80HP jet) with 10lb NOS bottle and connected/controlled by Syvecs(currently not mapped,but can be mapped upon request)
AEM Water Methanol kit(switcheable via Switch)
Hybrid(HDI) FMIC with Heat wrapped pipework
BuddyClub Spec IV 3" Exhaust
ECU
Syvecs S6 PnP ECU with 8 switchable maps ALS and LC enabled with NTK L2H2 (LZA-09-E1) Wideband fitted with JTi sensor pack
Transmission:
5speed PPG(1st-4th straight cut,steel selector forks,5th std)
This has been on Tesco Momentum T99(in US 99RON is 93),no NOS or meth
Meth and NOS will be mapped probably end of the month,but think meth only will be mapped,just due PPG will probably will not hold the NOS
Jura
jura11 is offline   Reply With Quote
Old 11-07-2013, 01:21 PM   #98
Calikid
Member#: 157491
03' JdmSti Hybrid
Emeral Green Pearl
Got 451whp/395tq @26psi on my fully built cosworth stroked 2.2L v7SB/v8 big port Heads with avcs&cams.
Old 11-08-2013, 01:46 PM   #99
Calikid
Member#: 157491
03' JdmSti Hybrid
Emeral Green Pearl
Old 11-28-2013, 11:41 PM   #100
Screw your v8
Member#: 363565
02 WRX
Rally wrapped
Well I finally completed my stroker build (see my build list in previous post )
Mega props to Dale at boxer4racing.com and the whole crew at 42 autosports !
I didn't make quite as much power as I had hoped, but I am happy with the results.
After an entire day on the dyno tuning, reflashing, and tuning some more .
We ended up with super driveable tune, that made 319 awhp 306 awtq
On a mustang dyno, I will post graphs next week when I return from vacation.
