Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
View Poll Results: best for DD/Weekend Worrior/low-end punch
ATP GTX3071R 1 33.33%
Blouch 20g XT-R 0 0%
Blouch 2.5XTR 0 0%
FP 71HTA 2 66.67%
Voters: 3. You may not vote on this poll
Old 07-31-2012, 02:48 AM   #1
amnvince88
Member#: 289978
2006 Sti
Default FP 71 HTA anyone running these?
I'll be in the market for a new turbo soon, looking to upgrade from my Blouch 18g running 310whp(91)...
my goals are 350 stock loctaion(91 pump w/ tmic). My priority is a hard punch(full boost/TQ) at the lower end (~4k). I'm interested in these turbo's below. I'm looking for anyone running these especially the FP 71HTA. Please give constructive insight on these if you or someone you know is running these, Thanks.
FP 71HTA -most interested
http://store.forcedperformance.net/m...Code=WRX-Turbo
Blouch 20g XT-R
http://www.bptstore.com/Subaru-WRXST...er-_p_122.html
Blouch 2.5XT-R
http://www.bptstore.com/Subaru-WRXST...rger_p_16.html
ATP GTX3071R
http://www.atpturbo.com/mm5/merchant...egory_Code=SUB
and before you start spouting the "use the search button", I have and I've found nothing on the FP in comparison the the rest.
amnvince88 is offline   Reply With Quote
Old 07-31-2012, 10:46 PM   #2
amnvince88
Member#: 289978
2006 Sti
anyone?
Old 08-01-2012, 11:04 PM   #3
Confusious2002
Member#: 10278
I come from the dsm world (i have an 11 sec small turbo full weitght dsm). the 71 is bad ass. dsm guns are running the fp 68hta deep into the 10s. To take advantage of it you NEED to run at least e85. I'm on a small 16g running 27psi on e85 my dsm pulls hard. Ppl run too little boost on these (decent) sized turbo's in the subaru world to really maximize the power. On pump you will defiantly see a power increase, but imho it's not close to bang for buck. Look into e85 or something bigger turbo wise. I don't see why you can't hit your power goals right now on e85.
Confusious2002 is offline   Reply With Quote
Old 08-01-2012, 11:26 PM   #4
LBell05STI
Member#: 305890
2005 STI
Edit:nvm
LBell05STI is offline   Reply With Quote
Old 08-01-2012, 11:28 PM   #5
kylem1853
Member#: 275019
On Cobb stage 2 i am 296, with a ****ty dyno tune on top of that making out injectors i was 315 this is on stock turbo 18 to 20 psi. i plan on putting in my 850's and that blouch 20g xtr and i already have the walbro 255 i hope to put down 360 to 400 so i don't know how you arent already there
kylem1853 is offline   Reply With Quote
Old 08-01-2012, 11:30 PM   #6
kylem1853
Member#: 275019
Sorry meant to say maxing out injectors
Old 08-01-2012, 11:32 PM   #7
amnvince88
Member#: 289978
2006 Sti
Well, ethanol is VERY enticing for me but being in Nor Cal we have 1 station about 20 miles away...so for DD its not practical, so I'm stuck with the piss water we have here. I came across the 71hta after my evo buddy started talking about it.
I called FP and they just released the 71HTA for the sti last month. I guess that's why I can't find anything on it. From what they said it's the replacement for the 68hta. On paper it's exactly what I'm looking for, but I'm really not brave enough to be a guinea pig, so I might hold back awhile and wait to decide between this and the Dom 2.5XT-R
Here's what they have posted:
"The FP 71HTA™ turbocharger for the Subaru WRX/STI features the 71mm HTA™ compressor section with your choice of 64MM stock appearing cover or 84MM Flow Advancement Port™ compressor cover coupled to the TD05H 8cm2 turbine section. This combo produces the fastest spool and transient response possible in any Subaru based turbocharger. The FP 71HTA™ flows 51LB a minute capable or producing upwards of 425WHP."
Old 08-01-2012, 11:35 PM   #8
amnvince88
Member#: 289978
2006 Sti
what dyno? and what fuel? I'm running on 91 and a low reading dyno. example my "stage 2" came in @ 279whp at 18psi, my base run was ~220whp
Old 08-01-2012, 11:42 PM   #9
kylem1853
Member#: 275019
93 octane on an Australian dyno which is apparently real numbers and 298 was my base line but it just really didn't want to make power after that it was 296 and 289 torque
Old 08-01-2012, 11:45 PM   #10
kylem1853
Member#: 275019
All i have is Cobb downpipe Invidia catback. Cobb sf intake.peering after maf. Jsc speed inlet. Grimmspeed aos. and a newer stock turbo. And access port
Old 08-01-2012, 11:45 PM   #11
kylem1853
Member#: 275019
That was Perrin after maf
Old 08-02-2012, 01:22 AM   #12
amnvince88
Member#: 289978
2006 Sti
^well we have two different animals we working with...
Old 08-02-2012, 10:57 AM   #13
kylem1853
Member#: 275019
What do you have?
Old 08-02-2012, 12:34 PM   #14
amnvince88
Member#: 289978
2006 Sti
An 06 sti... I was referring to the fuel and dynos...they make a huge difference.
Old 08-05-2012, 12:08 PM   #15
amnvince88
Member#: 289978
2006 Sti
lets keep this thread rolling...anybody have caparisons/opinions of the turbos in the poll?
Old 09-13-2012, 07:56 PM   #16
elbertmurphy
Member#: 268256
2005 STI
i'm looking at the fp 71hta with the 84mm compressor, ported and external waste gate. does anyone know what this would compare to 16/18/20/25g? what kind of power could you expect to see with this turbo as well? i really wish someone would make a quality 25g for subies. i'm not gonna play roulette with a ebay turbo.
elbertmurphy is offline   Reply With Quote
Old 09-14-2012, 02:39 AM   #17
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
How the 71HTA turbo new? Guy I know has had this turbo on his 06 WRX for 2 years. Its ok, nothing crazy IMO. I just pulled it off his engine today (blown head gaskets and worn rings). Turbo looks fine after 2 years of SCCA abuse, had 1/4 quart of oil sitting in it but that was from the Grimspeed AOS becoming a oil pump when the rings let go.
UK-Wagon is offline   Reply With Quote
Old 02-28-2013, 08:34 AM   #18
henria86
Member#: 303849
2004 Forester Xt
Silver stg2
any feed back???
henria86 is offline   Reply With Quote
Old 02-28-2013, 12:24 PM   #19
ppayer38
Member#: 234407
04 Self-tooned
STi
There is a thread already made on this turbo that explains pretty much everything about it!
ppayer38 is offline   Reply With Quote
