Old 07-31-2012, 09:56 PM   #1
BobbyGF8
Member#: 294040
1998 JDM WRX GF8
RED
Question Up pipe and down pipe question...
Hi all, I been searching for an answer.
I have a JDM GF8 MY98 fully stock, TD04.
The question is, does the uppipe has a catalyzer or a flex joiner?
Because I am looking for a catalyzer but I think there isn't. It has to be very little to fit there.
What do they mean?
Now, on the middle section, is there another catalyzer or a silencer?
Thanks for the help.
BobbyGF8 is online now   Reply With Quote
Old 08-01-2012, 01:56 AM   #2
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
The JDM Uppipe should not have any catalytic converters in them. And I do think they have a metal flex joint, but not 100% sure on that.
And a catalytic converter will help burn off un-burnt fuel, and convert some harmful chemicals into less harmful ones.
And your downpipe should have 1 cat in it and will be a bit longer than the USDM length downpipes. So if you were wanting to hook up a USDM length catback, you would want to get a USDM length downpipe as well. Other than that all of the exhaust parts from the 02-07 WRX will bolt right up, minus one hanger on the catback exhaust.
Hope this helps.
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
