Old 08-18-2012, 10:10 PM   #26
Elrukin
Member#: 329563
There is nothing you can do to stop oxidation, it comes back on a regular basis, Using a deoxidizer for acrylic headlights is safer, quicker and cheaper.
Sanding your lens is not be necessary if all you have is a oxidation issue.
Removing headlight oxidation is very easy and you don't damage the protective ultra violet layer of protection.
The lens needs a protectant just like the paint does.
You will need to apply it after deoxidizing and after each wash
If you don't apply a protectant on a regular basis, the oxidation will come back and you will have to clean the lens again.
Elrukin is offline   Reply With Quote
Old 08-18-2012, 11:00 PM   #27
aaron0815
Member#: 284922
2002 SC430
Red
any particular brand you would prefer?
aaron0815 is offline   Reply With Quote
Old 08-18-2012, 11:13 PM   #28
redrexmeister
Member#: 111692
04 wrx wagon
What he said ^^
I'd sand only if I had to remove scratches.
redrexmeister is offline   Reply With Quote
Old 08-19-2012, 05:57 PM   #29
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
Just for your benefit. I will post this as some can't use the search button. The oxidation comes from the uv coating. The only way to remove it effectivly is to sand it off and then polish the plastic. Then you have to consider how to deal with the uv coating now being gone.
Here is what I did and suggest. I used the 3m headlight restore kit. For $20. Then I used headlight film to prevent further oxidation, $50. Haven't touched the headlights since I did this. As well they look great.
Old 08-19-2012, 06:40 PM   #30
MD04WRX
Member#: 72891
2014 Molten ST
2000 2.5RS - 2014 XV
^^^ Ding, Ding, Ding ......... as noted in post #2
MD04WRX is offline   Reply With Quote
Old 08-19-2012, 11:17 PM   #31
emjp4
Member#: 290926
2005 WRX
Where are you getting the film? Are you just using vinyl from the likes of Lowes? Does Lowes sell UV resistant film that would be appropriate? Im tired of using my DA orbital, buffing the oxidation off with Plast-X every 2 months.. They get crystal clear, but start oxidizing again in 2 weeks.
emjp4 is offline   Reply With Quote
Old 08-19-2012, 11:21 PM   #32
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Use.
An automotive.
Clear coat.
You can buy it in a can at autozone.
Psychoreo is offline   Reply With Quote
Old 08-22-2012, 08:46 AM   #33
emjp4
Member#: 290926
2005 WRX
Originally Posted by Psychoreo
Use.
An automotive.
Clear coat.
So, go with vinyl. Got it.
Do you advise sanding before laying down the automotive clear? Or will a good cleaning suffice?
Old 08-22-2012, 08:59 AM   #34
Psychoreo
Member#: 79643
2015 WRX STI
Wet sand first. Depending on how bad it is you can start with 1000 or 1500, then 2000.
Plastic polish.
Clear.
Done.
Old 08-24-2012, 03:01 PM   #35
Jdub.csu
Member#: 283784
2013 EVO X GSR
http://forums.nasioc.com/forums/show....php?t=2393695
There you go. Will last a few years
Jdub.csu is offline   Reply With Quote
Old 08-24-2012, 04:06 PM   #36
daammnn
Member#: 330135
I use plastix
daammnn is offline   Reply With Quote
Old 08-26-2012, 04:42 PM   #37
builthatch
Member#: 185105
2009 C63 AMG
Palladium Silver
Originally Posted by Thomistopheles View Post
Here's what I recently started doing to restore headlights. I got this from a detailing forum, the results last a long time.
http://www.autogeekonline.net/forum/...lant-idea.html
Wetsand 400-2000 grit
Polish w/ Meguiars M105
Polish w/ Meguiars M205
IPA wipe
Coat with a 50/50 mix of Helmsman Spar Urethane and mineral spirits
Let it dry and you're done.
i think a lot of people missed this post. while i do not prefer the megs twins vs. the spray twins from OPT, this post basically sums up what is accepted by most to be the best way to get lights done right and to last several years once corrected.
i personally use optimum opti-coat and coat three times within the cure period to get a thicker film build but the spar method works fine for a lot of people.
the key is getting something with lots of UV absorbers on the lens once it's as clear as you want it. and...clearing with clear coat is unnecessary. the potential downside and mess is not worth it when you have much easier and more effective methods available.
the lamin-x (UV protecting headlight film) idea is interesting because it would also help against the number one enemy of any headlight treatment - debris and road wash. i just haven't tried it to know for sure.
builthatch is offline   Reply With Quote
Old 08-27-2012, 12:45 AM   #38
lil'redwagon
Member#: 10854
2002 Sedan V8 ej207
Dom 3 XT-R, 400WHP
i used a rockblocker film on my replacement ebay headlights. i got them just to use while i was deciding on what headlights to go with (broke my morettes). the plan was to get whatever headlights i could find CHEAP, and use them until they got cloudy. i applied the rockblocker film before they went on the car, and 6 years + 120K miles later, and they're still looking like new!
lil'redwagon is offline   Reply With Quote
Old 08-27-2012, 02:22 PM   #39
GrumpyTom
Member#: 330251
I didn't do this on my WRX, is it is still about a month old, however on my 99 Jetta (new style)I was in an accident in which one of my headlights needed to be replaced. So I had a brand new light, and a really old... super hazy (like, yellow) light.
I bought the 3M Lens Restoration kit. They are cheap, and they give you an abundance of sanding discs.
Be meticulous, charge your drill batteries (I was really thourough... went through the spare too) and follow the instructed grit sequence. It turned out so well that when I told people one was new and one was restored, very few of them could tell which was which.
GrumpyTom is offline   Reply With Quote
Old 08-28-2012, 10:40 AM   #40
fw_tab87
Member#: 330413
Originally Posted by 6Star_McCoy View Post
wow that looks great
fw_tab87 is offline   Reply With Quote
Old 09-11-2012, 08:37 PM   #41
anon_az
Member#: 160782
2004 Impreza WRX STi
Did mine last week with a $10 kit from Harbor Freight. Let's see how it holds up!
anon_az is offline   Reply With Quote
Old 09-12-2012, 12:38 PM   #42
FraziersEVO
Member#: 268333
IPA wipe
This guy has the right idea, only thing I would change would be to use a cutting pad with the M105 and a polishing pad with the M205. Seal them up when your done with a good sealant and your done.
FraziersEVO is offline   Reply With Quote
Old 09-12-2012, 07:09 PM   #43
bigblueman
Member#: 329135
2003 WRX
a cheap way is to use some toothpaste. it works okay and will take away the yellow haze.
bigblueman is offline   Reply With Quote
Old 09-24-2012, 05:27 PM   #44
dbrunone
Member#: 142333
After 6 years, my 2007 is showing some hazing. I ordered the 3M kit from Amazon, but I think I'm going to take the lenses off to do it, because I dont want to accidently hit the paint in the corners of the lights
dbrunone is offline   Reply With Quote
Old 09-24-2012, 05:37 PM   #45
Psychoreo
Member#: 79643
2015 WRX STI
Painters tape
Old 10-04-2012, 10:52 AM   #46
cineris
Member#: 263329
2011 Impreza WRX
Anything for the inside of a lens? mine fogs up due to a leak somewhere and now it looks hazy from the inside it seems.
cineris is offline   Reply With Quote
Old 10-04-2012, 11:45 AM   #47
Jdub.csu
Member#: 283784
2013 EVO X GSR
Bake the lights and get some selant from lightwerks rebake and your gtg unless the plastic housing has a crack
Old 10-04-2012, 12:02 PM   #48
ppayer38
Member#: 234407
04 Self-tooned
STi
A couple(3-5) coat of automotive clear will protect without an issues. Everytime you sand you sand away the factory UV/Haze protection and sooner or later you go through it. Same goes for buffing as it just takes less off but still removes some.
Clear coating puts that protection back on. The haze will come back but it will take a few years for that to happen while in mean time you can enjoy shiney new headlights matainence free.
Most shops will do it for aorund $50-100 if you do the prep work and give them just the headlights
ppayer38 is offline   Reply With Quote
Old 10-04-2012, 06:01 PM   #49
cineris
Member#: 263329
2011 Impreza WRX
Its not cracked but I think there's some residue on the inside of the lens
Old 10-04-2012, 06:22 PM   #50
Jdub.csu
Member#: 283784
2013 EVO X GSR
Then bake them and take them apart clean with denatured alcohol and then put back together with new sealant
