Old 08-01-2012, 12:58 AM   #1
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Default Gathering data - please help
Hey Guys -
I'm trying to get a feel for what the most popular brands of gauges are out there.
while you're at it if you feel like plugging in which ones you're running I'd appreciate it.
Thanks!
Old 08-05-2012, 12:27 PM   #2
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
Defi 'racer' series of stand-alone gauges.
Currently: 52mm / blue / boost-gauge / Subie Gal dash-pod; will keep
On order: SMY gauge-cluster bezel
To be ordered: Defi blue racer 52mm temperature (oil) and pressure (oil) gauges. Will more-than-likely order a Defi 'extension cord' for the temperature gauge sender, which will be located in the KBM oil pan and a remote pressure sending unit hose kit, in order to utilize the rear block port due to the DBW design of the TB.
I chose these gauges for their inherent quality and their stand-alone feature.
Old 08-05-2012, 02:13 PM   #3
jonthesloth
Member#: 184390
2005 CGM WRX
1999 Forester GREEN
I used to have Prosport Boost and Oil Pressure, but I had a problem with them lasting over a year or so. They looked great, cost is decent, but the gauges themselves have longevity issues. At least for me.
I want some Defi's
jonthesloth is offline   Reply With Quote
Old 08-05-2012, 11:34 PM   #4
JarHarms
Member#: 138994
2006 WRX Ltd
SGM 6MT and such
My experience has been best with Defi's premium lines. I run IMP and EOP meters and nothing else. However I am probably not part of the popular meter population, it will probably end up being ProSports (yuck) or (I can only hope) Defi Racers.
Would not even think to take an Autometer or ProSport out of it's box before I tossed it into traffic. I tend to be really really picky on meters. Have used quite a few meter brands through out the cars I have worked on, including Autometer, Stewart Warner, VDO, Greddy, Blitz, ApexI, Defi, and a few others. Since Defi Links are discontinued I would opt for Advance CRs. I recently wanted to try Stack ProControls but not sure how much they integrated after Autometer bought them.
JarHarms is offline   Reply With Quote
Old 08-06-2012, 09:33 AM   #5
sjs0433
Member#: 86061
Defi Racer series would be at the top of my list. Quality gauges that don't require a control unit which helps save on cost.
sjs0433 is offline   Reply With Quote
Old 08-06-2012, 02:33 PM   #6
69subaru360
Member#: 159682
1995 WRX
I have Omori in mine now. I've used autometer in the past. Both are very good.
I've had the displeasure of installing prosport. They are garbage I would never put them in my own car.
Message Board Statistics All times are GMT -4. The time now is 04:36 AM.
