#1 |
Member#: 218437
Vehicle:1992 Lego SS/Stagea |
Put in a set of std size acl race bearings in my ej22t and ran it for less then 50km, tore the engine apart again for forged pistons, sould I buy new bearings again or should I re-use these ones, crank surface looks great, but the bearing doesnt look as fresh as when they where installed, has some small marks on them in some spots.
I'll try to get some pics tonight.
#2 |
Member#: 71339
International
Vehicle:1995 WRX STi RA White |
For such low use I would re-use. Those bearings are not like head gaskets, which of course you must replace.
#3 |
Member#: 51480
International
Vehicle:1984 AM5, 1994 BC4, 2010 BR5 |
If they look good reuse them, no problem.
#4 |
Member#: 171039
NESIC
Vehicle:99 RSTi TypeRA LTD Black Diamond Pearl |
Probably wouldn't hurt to measure the clearances with some plastigauge. It's cheap and quick and won't leave you wondering if your clearances are out of whack or not.
#5 | |
Member#: 33174
RMIC
Vehicle:We are Open Late! 888-457-2559 Every day! |
![]() Thanks, Rick |
#6 | ||
Member#: 112759
Vehicle:02 Srp STi... R ur Boltz to long???? |
Looks
measure, measure,MEASURE!Quote:
I've re-used them after 30k or so.. but they spec'd out correctly of course! |
#7 |
Member#: 51480
International
If the bearings were measured when installing them first time and they are to be used on the same block/crank/rod combination and show no (obvious) signs of wear I'm pretty sure the will still be within spec!
In all other cases you are right ofcourse. |
#8 |
Member#: 71339
International
^+1. :d
