Welcome to the North American Subaru Impreza Owners Club Sunday February 1, 2015
Old 08-01-2012, 03:09 PM   #1
02 wrx roar
Member#: 199600
Question window issue any imput would be great
ok so my issue is i have 02 wrx swaped to rhd basicly fliped stock harness over and swap door harnesses from side to side...ect my issue is my windows only work when my headlights are on... now i know everyone wants to SAY i crossed a wire when wireing it but im possitive i didnt. my only thing that could be wired wrong is the jdm window switch i put in onthe drivers side it had to be repinned but i dont see how that could effect the window throw the headlights... if any one has any input that be great... its not a terrible problem be a explination would be awsome then i cound fix it hahah.
thanks
02 wrx roar is offline   Reply With Quote
Old 08-02-2012, 07:12 PM   #2
02 wrx roar
Member#: 199600
Help!!!!!
Old 08-02-2012, 07:52 PM   #3
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suggest you check for power at the main switch to see if you have it there when the window switch is turned on. There is a relay in the circuit I believe and maybe something is happening to that. There may be a issue with the chassis ground so if you want to see if that is the case you could run a temporary wire from the negative battery post and to a good point near the dash area. If those things don't show up anything then you will need to trace out the power from the window fuse all the way to the window switch and find out where the problem is.
Cougar4 is online now   Reply With Quote
Old 08-03-2012, 10:42 PM   #4
02 wrx roar
Member#: 199600
Well i put a jdm switch in and i got to of the pin outs wrong my front switch works right back window amd vis-versa the left rear dont work so im gonna jump a wire over so the back to work at the same time( no matter how i pin it the one side in the back wont work that why i wanna do that) but as far as the lights being in envolved idk so wat chassi ground everything else in the car works properly and they work just when the switch is on so im wonders how its gettn power from the lights to come one! The lights and windows wire should be completly seperate.... This relay u speak of is it gonna be going off hot for the whole system u think?
Old 08-04-2012, 12:50 AM   #5
Cougar4
Member#: 53443
Winestone
My info shows the ignition relay supplies power to the power window relay coil to turn it on. Power comes from the circuit breaker and passes through the relay and on to the power window switch on a grn/blk wire. There is a blk wire tied to the same connector that should be tied to ground for the return side of the window circuit.
Old 08-04-2012, 01:43 PM   #6
02 wrx roar
Member#: 199600
Ok ill check the relay and the wires on the switch again along with the gr/blck wire... Is there and wires tied in for the lights on that circut?
Old 08-05-2012, 04:35 AM   #7
Cougar4
Member#: 53443
Winestone
The ignition relay is supplied power from fuse 5 located in the main panel under the hood. Power from the ignition switch turns the ignition relay on. There is a junction point on the same wire from the ignition switch that also goes to the two headlight relay coils so they can be switched on by the headlight switch connection to ground. So it appears the power for the windows isn't passing through the ignition relay like it should be. Somehow it is tied to the headlight wiring.
Old 08-07-2012, 03:11 PM   #8
02 wrx roar
Member#: 199600
Default windows
ok that makes sence im gonna try to track it down on friday is there any way u can send me that diagrram email sweeney1988@yahoo.com or to my phone 5405501226 that would be awsome...
one other question by any chance do yoy know where to fine a rhd pin out fror the drivers door window switch
