Old 08-01-2012, 02:40 PM   #1
PULMEOVR
Member#: 222724
2005 Impreza RS
Regal Blue
Question Seafoam (Again, sorta) ...
Hi guys,
Another Seafoam thread, I know!
I'm looking to Seafoam my '05 RS this Friday. Based upon NASIOC searches I've conducted, it seems that I can use a vacuum line off of the throttle body. Does anyone know which line this is? Can I remove this line and let it suck from a bowl/cup of Seafoam? Or do I have to buy a hose to connect to the TB (if you know what I mean) so it feeds toward the TB and not the other way around?
I'll also be adding it to the crankcase & fuel tank. I've got 136,000km (about 85K miles). I'll let you guys know how it goes.
Thanks for your help.
Matt
PULMEOVR is offline   Reply With Quote
Old 08-01-2012, 02:55 PM   #2
PULMEOVR
Member#: 222724
2005 Impreza RS
Regal Blue
Also, is this an appropriate schematic and cleaning procedure for the IAC valve?
http://home.comcast.net/~lawsonmh15/...ve_Service.pdf
EDIT: Ooops, I don't think our cars have an IAC due to DBW (2005+)?
Old 08-03-2012, 12:16 AM   #3
PULMEOVR
Member#: 222724
2005 Impreza RS
Regal Blue
I've searched but the answer isn't clear.
Anyone?
Old 08-05-2012, 04:45 AM   #4
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
This may or may not help, but regular Seafoam is available in an aerosol can now. It comes with a huge straw and a guide to bend it.
I think most of the hoses pre-throttle body and post-MAF should work okay.
Counterfit is offline   Reply With Quote
Old 08-05-2012, 08:30 AM   #5
hoffmanEstates
Member#: 122043
04 wagonier
psm
you can seafoam any hose that has vacuum. seeing you don't have maf but use a map sensor. remove.intake and expose t.b start it and start pouring it into the t.b best way to do.it as vacuum hose sometimes only reach 1/2 motor....
hoffmanEstates is offline   Reply With Quote
