Welcome to the North American Subaru Impreza Owners Club Wednesday July 29, 2015
Old 08-07-2012, 06:00 PM   #76
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
we will run em again from different rpm. .
i guess after reading the reviews on this turbo i had high hopes for it.im not saying my car is slow or anything just not as big of a difference as i was expecting.
on the vf i was dyno tuned and then had phatron tune it later on to try and get rid of some hesitation, i liked phatron's tune better, it was more fun. thats why i went with him again. i dont want this thread to be negative towards him,he's been helpful
can you compare time between one person log and anothers? like how long it takes from 4-6k rpm and compare it to how long it takes the other guy to go 4-6k? mine and northman log was similar in time too. a higher power car would make it to 6k faster wouldnt it?
say i went to same dyno. would it dyno at 350hp, but log 300g's or dyno at 300hp? trying to understand the whole g's thing
spec_bg is offline   Reply With Quote
Old 08-07-2012, 06:10 PM   #77
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
That is the basis for doing airboy plots. If you know the weight of the car+driver, the time to accelerate will let you plot the power curves. Our cars are similar, so it should work well enough. Flat road and average of both directions would be best.
northman is offline   Reply With Quote
Old 08-07-2012, 06:28 PM   #78
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
romraider wont let me do that, something about car definitions not being found. we downloaded the car def when we installed RR but something didnt go right. i can do everything else except use the dyno tab
Old 08-07-2012, 06:30 PM   #79
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
we
the g/s is a meaningless number between vehicles. it only means something on the car its on.
as far as dynos go....it depends what dyno you go on. Like the link i posted above from EFI and 310whp or Topspeeds 370 whp.....same boost.
Old 08-08-2012, 12:02 AM   #80
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Defintiely don't use the RomRaider dyno function. It does not work very well. Just pull a few logs from 2k-redline and then plot them with Airboy or Virtual Dyno (VD is easier). Then if you have a log from the VF car, you can compare. This takes the dyno variation out of the mix (as long as you both get good logs from flat roads and enter the weight info correctly).
As Phatron already said multiple times, the g/s is meaningless for comparing between cars. It all depends on the MAF scaling.
xluben is offline   Reply With Quote
Old 08-08-2012, 02:01 PM   #81
Phatron
Member#: 36033
CEO PhatBottiTuning
here ya go. northman vs spec bg.....feel better now?
northman red, brandon black
Old 08-08-2012, 02:20 PM   #82
neorex
Member#: 106478
STi 1.5 xt-r
neorex is offline   Reply With Quote
Old 08-08-2012, 06:12 PM   #83
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
hell yeah i feel better. i hope you understand why i was concerned.
thank you northman and phatron
Old 08-09-2012, 04:50 PM   #84
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Phatron tuned
Phatrons the best : )
wrxsubiemod is offline   Reply With Quote
Old 08-11-2012, 03:05 AM   #85
Phatron
Member#: 36033
CEO PhatBottiTuning
I just posted this in the other 1.5xtr thread...but believe its suited here too
"Originally designed for our 2.0L customers in the UK, the Dom 1.5XT-R uses the Garrett GT 56.5mm turbine instead of the full 60mm turbine of the Dom 2.5XT-R. The end result is a slightly quicker spooling turbo while trading off some high RPM horsepower capability."
IMO there is no reason to run this turbo on a 2.5L.....10cm2.5xtr is what should be put on a 2.5L
The 1.5xtr is basically a 20gxtr with a slightly bigger compressor wheel that does abosultely no good cause the turbine is choking it.
Old 08-11-2012, 08:48 AM   #86
spec_bg
Member#: 226517
04 FXT dom1.5xtr
psm
what is the rpm spool difference between the 1.5 and 2.5 that you see when tuning both?
Old 08-11-2012, 10:56 AM   #87
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
I peak a little bit before 4K. From what I read I other post the 1.5 peaks mid 3000.... sorry (edit)
I start boosting right before 4k and peak at 4.5k. I realized that after looking at Ron's plot.
punchjamesarnol is offline   Reply With Quote
Old 08-11-2012, 01:43 PM   #88
Phatron
Member#: 36033
CEO PhatBottiTuning
Old 08-11-2012, 02:20 PM   #89
BigRob74
Member#: 305107
2012 wrx
360/386 E85
Originally Posted by Phatron View Post
thanks for posting that, seems the dom 2.5 is better for the bigger motor
BigRob74 is offline   Reply With Quote
Old 08-11-2012, 03:21 PM   #90
BlazeRex
Member#: 268354
02 WRX 05 LGT
Slow Automatics
I hate when people expect a certain result from a car and then jump on the tune or parts when they dont get it. The car will make what it makes. Just cause one guy said his car made X whp and Y rpm spool on Z turbo, doesnt mean yours will do the exact same, or even remotely close. Everything from weather, compression, coil packs, clutch, etc can change the results.
Go through a dyno database and type in a certain turbo and compre a few cars equipped with them. You'll see what I mean. The graphs usually resemble each other, but are nothing like being exact. Sometimes even close to 500rpm+ spool difference.
BlazeRex is offline   Reply With Quote
Old 08-11-2012, 05:46 PM   #91
Phatron
Member#: 36033
CEO PhatBottiTuning
^ exactly. And people have to realize that folks like me or even big shops don't have time to test every single setup. Each person comes in with different parts and different running cars.
You can go on efis dyno database and plot up the 20gxtr, dom 1.5 and dom2.5 and depending on which setups you pick to plot against the others you can make a case for each turbo outperforming the others. But none of them have the same combination of parts or even the same boost levels.
Old 08-12-2012, 02:35 AM   #92
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
I don't want to sound like a homer, cause I have the 1.5, but the way you present that graph is a bit misleading. The 1.5 boost does not appear to be anywhere near maxed out, as evidenced by the flat, non-tapering curve. To look at that and conclude it has no top end capability would be a stretch.
Old 08-12-2012, 02:41 AM   #93
Phatron
Member#: 36033
CEO PhatBottiTuning
It was not meant to show top end capability....it was meant to show spool.
Brandon asked about spool so I posted a boost plot. Simple as that.
If I wanted to show top end capability I would simply post the turbine and compressor specs again.
Old 08-12-2012, 02:53 AM   #94
northman
Member#: 163631
07 Forester XT
Dom 1.5XT-R
I agree, I am really responding more to the guy who posted immediately afterward concluding the 1.5 was not a good choice for the 2.5L.
I would love to see a family of curves that show different turbos maxed out on boost, to get an idea how much they can flow around redline.
Old 08-12-2012, 03:01 AM   #95
Phatron
Member#: 36033
CEO PhatBottiTuning
Just go on a dyno database like efis and make plots.
You will come to the conclusion that the turbo is not the only factor.
You can make a multitude of comparo plots that show the 20gxt, the dom1.5 or the 2.5 to be the superior turbo.
But in the end, the turbo specs should hold up to be true. A completely maxed out 20g should not make more power than a 1.5 and a maxed out 1.5 should not make more than a 2.5.
Old 08-12-2012, 12:50 PM   #96
climbhigh09
Member#: 254163
2011 WRX 20GXTR
I'm actually glad to see this thread after all the recent noise about the 1.5 being the best thing for the 2.5L since sliced bread. There have been some insane numbers thrown out for that turbo... faster spool and more top end than the 20GXT; making it a magical turbo that lots of people are jumping all over.
Blouch knows their stuff, and I'm sure the compromises for the 1.5 make it a really nice turbo (to the degree that I have one sitting in my garage for testing against my 20GXTR some day), but it's been painful to see all the spray about people expecting this thing to break the laws of physics when they strap it on their car.
In the end... pulling against a VF from <3.5+RPM with a larger turbo will always leave you in the dust, unless you're willing to push speeds WAY past what would be reasonable on the open road. New engine systems require new driving considerations, simple as that.
EDIT:
whoa... didn't see the pick on my phone. I agree- you're trying to show a boost plot- my 20G hits 21psi before 3.7kRPM. Granted, I've done what I can for a quick spool, but this isn't pushing the 20 at all; is it really that close to a 2.5 on a similarly built system?
climbhigh09 is offline   Reply With Quote
Old 08-31-2012, 08:22 PM   #97
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
what is the latest on this?
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 10-02-2012, 12:31 PM   #98
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
i want to chime in an say that i am having similar experiences with my DOM 1.5xtr. I have had almost the identical discussion with Ron, as he also tuned mine.
I want to say that this turbo is not all its cracked out to be, and i like many others have fallen for topspeed's propaganda on this turbo.
While i like this turbo better than my VF, it didnt live up to my expectations. Topend is definetly better, i enjoy the linear power delivery, but the low end is gone, and i am starting to miss it. It became immedietly apparent when pulling a VF suby locally and me being suprised i didnt smoke him
I am hoping that meth injection is going to bring this turbo to life, and get close to the results we have been lead to expect from topspeed's testing.
*Ron, is there anyway you could add my dyno plot to the above with OP and northmans to get a 3way comparo going? I am just curious as well as to how mine stacks up.
i am REALLY hoping meth can get me in the 340-350 range, with hopefully more improvement in the midrange torque. Just hope the stock block will hold that much, we will see
07VTRex is offline   Reply With Quote
Old 10-02-2012, 02:49 PM   #99
Phatron
Member#: 36033
CEO PhatBottiTuning
it takes a while to plot them up against each other. heres your plot....another with kelford264 cams and another on e85. Note on the e85 car....its only running 21psi since it has a stock map sensor.
2007 WRX 65mm DW750 Dom15xtr TMIC EBCS EXT 93 Oct
2011 WRX TBE Per72mm DW750 Dom15 GSEBCS PWTMIC TBE 264Cams 93 Oct
2009 WRX Dom15xtr10 DW1000 KS73 FMIC TGV AirP Ext MBC E85
Old 10-02-2012, 02:56 PM   #100
07VTRex
Member#: 179023
07 CGM WRX TR
Dom 1.5xtr + PPG's
thank you for posting that Ron.
When the time comes that i can ad meth to my setup, would you expect it to look similar to the e85 plot(3rd one down)? Better yet, when comparing meth to e85, how would you expect the plots to differ? It is obviously not going to shift the powerband like the cams will.
For anyone else who may be wondering, will alternate fuel such as meth or e85 do anything for midrange tq or earlier spool, i.e. can it shift the graph to the "left" at all? Or does it help with increasing power evenly, i.e. does it simply shift the graph "up"?
It seems all the plots share one thing in common: lack of midrange torque. Can more midrange boost be squeezed out with this turbo, given the right fuel, with boost tapering off up top, not unlike a vf turbo? Or is it better to not have a boost taper at all?
After getting used to this setup, i really like how the turbo does not "fall on its face" like the VF turbos do, however i miss the mirange punch. Can this turbo do both or is it simply mechanically not-possible?
