Old 08-02-2012, 06:10 AM   #1
subietuner2000
Member#: 299559
2000 impreza
blue
Default Stroker kit??
Hey there,I think I want to keep my car NA,I have a 2000 Subaru impress 2.2l ej22, I was wondering.if anyone can help.me with a Stroker.kit
subietuner2000 is offline   Reply With Quote
Old 08-06-2012, 02:19 PM   #2
Gc808
Member#: 189683
if your looking for power a swap is cheaper, ive gone that route.
Gc808 is offline   Reply With Quote
Old 08-06-2012, 02:28 PM   #3
rs2.5er
Member#: 323238
exactly what he said. i have a few friends with that and they said they would rather have swapped...
rs2.5er is offline   Reply With Quote
Old 08-06-2012, 07:14 PM   #4
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Slap a 2.5 block under your 2.2 heads. Instant 40+hp, much more if you do cams and other goodies.
cal_look_zero is offline   Reply With Quote
Old 08-06-2012, 08:57 PM   #5
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
^^^ What this guy said.
WAY cheaper than a swap. Of course 40hp will only tide you over for so long...
~Josh~
Old 08-06-2012, 09:02 PM   #6
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
~Josh~
Tis true. I'm up near 210 bhp and it's not all that amazing, but it's a helluva lot better than the 135 bhp stock. Better fuel economy too... for some odd reason. Then again I built the engine from the ground up for $1400 and didn't have to monkey with wiring harnesses, tune, IC piping, or anything else.
Catch 22
Old 08-07-2012, 12:15 PM   #7
danscomp
Member#: 305358
Catch 22
What on earth did you do to get 210bhp out of a 2.5?
danscomp is offline   Reply With Quote
Old 08-07-2012, 01:13 PM   #8
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Probably cams and some other stuff.
Counterfit is offline   Reply With Quote
Old 08-10-2012, 04:02 PM   #9
subietuner2000
Member#: 299559
2000 impreza
blue
Where can I find a block at for a reasonable price??and suggestion on legit sites
Old 08-13-2012, 03:22 PM   #10
robdizzy
Member#: 328703
2010 Impreza 2.5i
Dark Grey Metallic
210 bhp? what is your current setup?
robdizzy is offline   Reply With Quote
Old 08-14-2012, 12:22 PM   #11
Sleeper_RS
Member#: 305380
^^ yes I want more info. Maybe he confused bhp and CHP. If not, more info!!! I want 210 bhp
Sleeper_RS is offline   Reply With Quote
Old 08-14-2012, 12:38 PM   #12
mustardman
Member#: 258718
07 2.5i
Buy it used...and local so you can inspect it and I doubt many people are willing to ship. You can rebuild it yourself and drop any goodies you want into the block
mustardman is offline   Reply With Quote
Old 08-14-2012, 03:23 PM   #13
subietuner2000
Member#: 299559
2000 impreza
blue
I live in Tucson,I don't know if ill be able to find one used locally here
Old 08-15-2012, 04:48 PM   #14
robdizzy
Member#: 328703
2010 Impreza 2.5i
Dark Grey Metallic
That's what i'm saying, I would love to find a way to get 210 BHP out of my NA.
Old 08-15-2012, 05:21 PM   #15
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Sorry, I meant crank hp. Around 175 whp.
Heads with some work/valves, cams, thinner HGs (pulling as much CR as I can) larger injectors, phenolic spacers under the IM, full intake and exhaust, balanced internals, lightened flywheel; I'm probably forgetting something.
Long story short, it's the cheapest and easiest way to obtain near stock WRX power in a 2.2 car, but that's where you cap it off at. No way to bring out much more power unless you go full retard and go high comp pistons, piggyback, meth, etc. And at that point, you should just swap a turbo engine in.
Old 08-15-2012, 07:29 PM   #16
robdizzy
Member#: 328703
2010 Impreza 2.5i
Dark Grey Metallic
Yeah, I am currently reading every forum post alive to find ways of getting as much HP as possible out of my NA.
Old 08-15-2012, 09:20 PM   #17
mustardman
Member#: 258718
07 2.5i
Haha don't bother...here it is.
EL headers (TWE headers, ceramic and wrap)
Straight pipe exhaust (no cats, and make the exhaust flow as straight as possible)
Intake (hybrid or CAI)
Intake Manifold Spacers (Grimmspeed)
Bigger Injectors
LW Pulleys (Maybe even underdriven)
11:1 High Compression Pistons
TWE/Delta Cams
New Valve Springs
PNP EVERYTHING POSSIBLE (Manifolds/exhaust/heads)
Custom Tune
IF your trying to maximize on your power than:
Weight Reduction (Spare tire, interior stripping)
Lighter/Smaller Wheels/Tires
Stiffen up the drivetrain
Better Clutch
Stiff Bushings all over the place
I suggest reading this awesome thread on rs25, its an age old thread over here where people debate the potential power with only bolt ons but they provide much more information.
http://www.rs25.com/forums/f5/t2912-...-bolt-ons.html
Old 08-16-2012, 10:27 AM   #18
robdizzy
Member#: 328703
2010 Impreza 2.5i
Dark Grey Metallic
Thank you for the thread you posted. Seems when it comes to NA every thread has the same info or argument on how to gain or lose HP when altering factory equipment lol.
Old 08-16-2012, 01:29 PM   #19
Sleeper_RS
Member#: 305380
Agreed
Old 08-16-2012, 07:31 PM   #20
mustardman
Member#: 258718
07 2.5i
Personally I think with a full exhaust/intake/LW Pulleys and some internal work like cams and you will be very happy. Just the exhaust alone will make you grin when you hear that n/a rumble. (n/a engine is louder than a boosted engine as the turbo silences the exhaust a little)
Old 08-16-2012, 08:09 PM   #21
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
I/H/E and cams are the single best bang for the buck, and are relatively easy to do. I scored a pair of 2.5 engines for $150, so that's why I went the route I did, however it was more work than intended.
I make more than enough power for what I use my car for, and more than what I make now would be superfluous; I have a bike to go really ridiculously fast on.
Being NA, it's a dream to drive off road and pitch sideways, easy to crawl around in the rocky areas near the river that I fish/kayak, and the power rolls in smooth for sketchy driving like deep snow or sand.
