Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 04-28-2001, 05:47 AM   #1
2yLiTe
Member#: 660
Post Which Transmission Fluid to use?
I wanted to buy some transmission fluid (5MT) and was wondering what everyone else is using.
2yLiTe is offline   Reply With Quote
Old 04-28-2001, 06:35 AM   #2
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
Post
Redline MT-90
http://www.redlineoil.com/redlineoil/mtlti.htm
For explanations, see www.cobbtuning.com under the technical bulleting section...
JoeT is offline   Reply With Quote
Old 04-28-2001, 07:53 AM   #3
2yLiTe
Member#: 660
Post
Ok, I've heard about Redline, but it's not easy to find. I'm in the Windsor/Detroit area. Are there any places that stock this? or is there anything else I can use off the shelf?
Does Canadian Tire, or Pep Boys have anything?
Old 04-28-2001, 08:07 AM   #4
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Post
Their recommendation could cause you warranty problems. The oil you use must meet or exceed Subaru's spec.
MTL and MTL-90 are API <A HREF="http://www.redlineoil.com/redlineoil/mtlti.htm">GL-4 rated</A>.
Subaru specifies a API GL-5 oil or higher.
If you call Redline, and you give them the API rating requirement and viscocity you will be told the correct oil to use is <A HREF="http://www.redlineoil.com/redlineoil/gearolti.htm#75W90NS">75W90NS</A> in the manual transmission, and 75W90 in the rear diff.
Glenn
[This message has been edited by Glenn Wallace (edited April 28, 2001).]
ANZAC_1915 is offline   Reply With Quote
Old 04-28-2001, 03:15 PM   #5
jhuang76
Member#: 1284
2005 Legacy GT
Royal Blue Pearl
Post
Okay, this is mix that I learned from PK Motorsport. BUT, I tried it out and it works GREAT (esp. in the Georgia heat)!!!
Use 2 parts RedLine 75w90NS and 1 part 75w140NS for the tranny!
I can shift a little faster w/o any grind (and did one clutchless shift but that's it) at all temps!
jhuang76 is offline   Reply With Quote
Old 04-28-2001, 05:04 PM   #6
Brian
Member#: 68
Post
We have a place here in Ann Arbor that stocks it.
Brian is offline   Reply With Quote
Old 04-29-2001, 12:04 AM   #7
2yLiTe
Member#: 660
Post
See? now that's what I wanted to hear!
Thanks Brian, can you give me the name of the shop? I work in Detroit and from time to time, get out to the burbs.
Which Redline Tranny/Rear Diff Fluid to use for 6Spd??? NotoriousD Service & Maintenance 3 04-29-2006 03:39 PM
Which Redline Transmission/Rear Diff fluid to use? Info please! NotoriousD Transmission (AT/MT) & Driveline 3 04-25-2006 10:30 PM
Best Transmission Fluid to use? nolanslv Legacy Forum 1 08-04-2004 10:56 PM
Which manual tranmission fluid to use? Cjchaps Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 08-27-2001 04:49 PM
Which Brake Fluid to Use? silverSurfer Brakes, Steering & Suspension 21 02-03-2001 12:27 AM
