Old 08-03-2012, 02:02 AM   #1
Danger Doug
Member#: 269207
2011 WRX
Default 2011 WRX Stage 1 Underboostage
Flashed to stage 1 today. The following are two pulls in third gear from 2000 rpm's to redline'ish, done one after the other. All day I haven't seen any sustained boost pressures above 15.5; however I'd get the very short spike of 16.3psi under spirited conditions. I tried the HWG map, and got sustained 17.5+, which seems undesirable (I'm told this is ok by some folks, so long as there isn't any knock). Any advice and help would be appreciated, thanks!
Pull 1
Pull 2
Danger Doug is offline   Reply With Quote
Old 08-03-2012, 09:34 AM   #2
Cobb Tuning
Member#: 4803
Pull 1
Pull 2
Logs look good - you are underboosting a bit, but not too bad. If you want to try the HWG map again, I would get another 3rd gear data log to see how it looks and also see what boost likes like in 5th gear when going wide open throttle.
Bill
Old 08-03-2012, 02:14 PM   #3
Danger Doug
Member#: 269207
2011 WRX
Thanks for the quick reply, Bill!
Installed the HWG stage 1 map this morning. First three are in the morning when temp was at 85 F, and the final third gear pull was after a 20 mile trip on the highway and ambient temp at 100 F. I couldn't (Shouldn't) get much higher than 4500 rpms in fifth, due to traffic and road conditions around here, so I hope the WOT fifth gear data is sufficient for what you're looking for. Thanks again, and have a good weekend!
Third Gear 2000 to red
Third Gear 2k to Red, into Fifth Gear WOT
Fifth Gear WOT Random Log
Third Gear 2000 to red Later Day
Also: Am I pushing the car too much that I'm affecting the longevity of the motor vs. the stock map with 17.5psi? This is my daily driver, and while I want to get as much power as I safely can, I can't afford to be fixing anything drastic now or down the road. Thanks!
Old 08-04-2012, 08:39 AM   #4
Cobb Tuning
Member#: 4803
Everything looks good with the HWG map. There's no issue with running the level of boost that the map is designed for, but if you want to stay more on the conservative side, you can always reflash the 91ACN version of your map (our most conservative map), assuming you are not already running that map.
Bill
Old 08-07-2012, 08:44 PM   #5
Danger Doug
Member#: 269207
2011 WRX
I ran another log in fourth gear from 2000 to red, and saw some weird learned knock mid pull. It went away, but any reason why it would be in that range, and not anywhere else? Is this false knock that's been learned, or should I run a bit more conservative? Thanks for the advice! It's greatly appreciated knowing someone who knows wtf is here to make sure I don't do anything stupid
4th Gear Pull
Old 08-08-2012, 09:44 AM   #6
Cobb Tuning
Member#: 4803
4th Gear Pull
That appears to be a single knock event that was learned during this run. It did start to learn back to zero even during the run, so it wasn't excessive and not a huge concern unless it is repeatable. I would take a few more logs. It may just be the high outside temps. If you want to stay on the conservative side, you can always reflash the 91ACN map, if you aren't already on that map. Or stick with the normal wastegate map.
Bill
